trunk opener fuse is good but can't open the trunk w/ the opener nor the key.
i tried to mess around w/ the silver latch looking thing w/ a broom stick but didn't really help cause i didn't know what i was doing. could the cable snapped?
needz some helps
needz some helps
One time my trunk was stuck because the trunk cable was hung up/stuck on something that was in my trunk...but that was when I had my trunk liners all pulled off.
What I did to fix it was pull my rear seats and metal panel behind them, climbed into the trunk and played with the cable and latch mechanism with some one pulling on the trunk release...
but anyway I seriously doubt the cable is snapped
If the key doesn't work, then it's not the tab.
Did you do anything to the car immediately prior to the trunk not opening?
You might have flipped the valet lock on the latch before you closed it... You might have top climb in the trunk like previously stated... But try wd40 in the key hole and try the key again??? Dont snap your key!!!!
i removed my rear seats before but not the metal panel. how long does that take? a lot of bolts involved?Originally Posted by 96blackmaxSE
One time my trunk was stuck because the trunk cable was hung up/stuck on something that was in my trunk...but that was when I had my trunk liners all pulled off. What I did to fix it was pull my rear seats and metal panel behind them, climbed into the trunk and played with the cable and latch mechanism with some one pulling on the trunk release...
nah man. i didn't even mess w/ the latch, tab or whatever.Originally Posted by pmohr
If the key doesn't work, then it's not the tab.Did you do anything to the car immediately prior to the trunk not opening?
Quote:
Maybe a half dozen bolts, a few more. Actually IIRC it's a mix of 10mm head bolts and nuts.Originally Posted by G4nismo
Quote:
yeh, i'm prob gonna have to climb in there. Originally Posted by BORQUA79
i doubt about the wd40. like the key will turn but nothing happens...
Quote:
thanks, thats not bad at all. thank God my tools and socket sets aren't in the trunkOriginally Posted by pmohr
Quote:
dunno whats the problem, tried wd lol, didnt work, oh well
take your lock out and soak it with wd40 and or PB Blaster, it's probably corroded stuck (been there done that)Originally Posted by Ultrastar
my trunk cannot be opened with my key too, but at least the button worksdunno whats the problem, tried wd lol, didnt work, oh well
alright, i took everything out today but how do i actually unlock the latch?
i tried flipping the latch up you see in the pic but it doesn't open the trunk.
On both my '99 maximas, the ignition keys do not open the trunk? what the fuxorz is going on? as far as im concerned, the locks or keys havent been replaced on either car...
mine did the same thing. use little screw driver instead of key. it should open. if not, put down the armrest in the back, go through that way, and with a long bar you can reach the latch to pop it open.
While lifting the tab in the trunk have someone push the trunk release button or use the key again after putting the wd-40 in the key hole...
Quote:
are you saying that will work or saying thats a possibility?Originally Posted by BORQUA79
like the latch won't stay up in the open position even when i lift it up.
when i push the release button, the latch opens like halfway and then closes again.
Does the button make a click or no? And what key are you using?
If you're using the master key (the black one), the trunk should open no matter what. Then it may be that the trunk is in valet mode, which is supposed to lock the trunk to the valet key and the button, supposedly keeping you safe from evil valets who want to steal your worldly possessions. Valet mode is controlled by the little silver switch by the latch in this picture:
Quote:
If you are using the master key, go ahead and flip this switch, then try again. If you're using the spare/valet key (the silver one) don't do this - you'll lock the trunk to the key, too.
