anyone got a write up on how to change control arms/balljoints?
May 2, 2009 | 03:52 PM
yes serched, no cant find
May 2, 2009 | 04:16 PM
Fail at searching.
http://forums.maxima.org/4th-generat...g-install.html
http://forums.maxima.org/4th-generat...s-serched.html
Interesting, enik23, enik24...
You even fail at spelling exactly the same, and use the same typing style.
Quote:
yes serched
Just as in the thread title above. So you can't search for your own thread?
May 2, 2009 | 05:46 PM
It's pretty straight forward really. Unbolt, seperate, push the old joint out, press the new one it. Have fun with the retainer clip. Mine was rusted into the arm, but I finally found it. You have to remove the axle from the hub to get room to get at the ball joint. Hope you have a 36mm socket.
May 3, 2009 | 03:36 AM
I actually did a write up for 3rd gen with pics, its NOT that different aside from the ball joints being pressed in and held with a snap ring vs 3- 19mm bolts, I believe it was in a thread created by vqmaxman or something like that. If you decide to search for it, its in the 3rd gen section and posted around Christmas time 2 years ago or so
