cornering bulbs on 95
Old Nov 22, 2001 | 11:22 AM
madmax26
ok lemme get this straight, cuz going through search im seeing that u have to rewire, u dotn have to rewire etc.... i have a 95 maxima and have white/blue cornering lights (small ones next to headlights that get brighter when turn signal is on) Can i just shave off one of those lil black nubs from the actual light bulb and put it back in???? or do i have to completely rewire, either or a description would help, thanks.
Old Nov 22, 2001 | 01:32 PM
NYCe MaXiMa's Avatar
Re: cornering bulbs on 95
If you want to shave the little **** off the bulb, you do not have to rewire, just do this:
Take out the 1157 bulb... it should have 2 little nipples on the sides of it, opposite sides of one another, 1 is higher then the other one... shave the HIGHER one. Then take the bulb and put it in backwards, so the lower nipple that is still left will line up and go directly into the higher socket thingy where the nipple you just shaved used to go.... it will make them a LOT brighter then stock... I just did this tuesday and damn, now they are even brighter then my headlights (because headlights have ****ty bulbs). hope this helped.
Old Nov 22, 2001 | 01:54 PM
cooler2000's Avatar
Re: Re: cornering bulbs on 95
make sure it doesnt burn your wirings like it happened to other members
Old Nov 22, 2001 | 04:51 PM
Re: Re: Re: cornering bulbs on 95
I hope it won't we'll see.. I upgraded the fuse too.. there is a bunch of people running this for a long time without problems... The guys that burned the wiring probably ran on higher wattage bulbs or something
Old Nov 22, 2001 | 07:10 PM
madmax26
thanks!
Old Nov 22, 2001 | 07:13 PM
mb1's Avatar
mb1
If you do that to a 95 won't it make the corner dimmer when the blinker is on?
doctorpullit
Mar 29, 2016 11:08 AM
mpbclutch33
Dec 26, 2015 11:11 AM
knight_yyz
Nov 1, 2015 01:34 PM
Noela
Sep 26, 2015 08:22 AM
