Cleaned my TB ... Leak ?
Old May 7, 2009 | 02:20 PM
mahanddeem's Avatar
Hi
Just finished my throttle body cleaning.........I took it apart , cleaned it , put a new gasket for it then returned every thing back in position perfectly....(TB butterfly was very dirty in the back of it)
Car now is with better response , jumpier than before ........But I am always suspicious about my car and always feel I missed some thing,I can't tell wether there is an air leak from the area of TB (or its new gasket) or not !!! seemed leaking when pressing the gas pedal and rev 1.5k to 2K rpm ? but afterwards , I accused myself of being paranoid
and everything is noraml ....
How can I judge there is a leak or not ?
1-Any air leak can cause CEL to light ? (it was off before the cleaning , still off now after cleaning......no problem so far about any CEL)
2-Maybe the IDLE with be higher ? (the idle is exactly like before the cleaning)
3-Leave everything and start enjoying the bit of improvment after TB cleaning ?
thanks
Old May 7, 2009 | 03:28 PM
pmohr's Avatar
No more Maximas...
A vac leak after the MAF can cause a code, yes. It may or may not, however.
The idle would most likely be less stable, and higher.
Why do you assume there's some sort of vac leak?
Old May 7, 2009 | 04:37 PM
mahanddeem's Avatar
I thought that there is a leak from the new TB gasket althought I installed it fine........How can I test that area ?
And is it possible that it leaks only when the RPM is 1400 and up ??? or it will leak all the way when the engine running ?
Old May 9, 2009 | 11:37 AM
mahanddeem's Avatar
bump
Old May 9, 2009 | 11:40 AM
pmohr's Avatar
No more Maximas...
Again, why do you assume there's a vac leak? Are you getting any sort of symptoms, or is it ESP? You never clarified.
A leak is a leak, it's going to be present whether or not you're at 1400 RPM.
Search, you'll see how to test with many things; smoke, brake parts cleaner, propane, etc.
Old May 11, 2009 | 11:58 AM
nitromax's Avatar
we've entered a dimension not of sight nor sound, but of mind....the twilight zone!!!
or dementsia
Mar 12, 2020 12:06 AM
The Wizard
24
Oct 1, 2015 08:47 PM
JoshG
51
Sep 21, 2015 10:41 PM
followthadollar
Sep 17, 2015 06:31 PM
seesole
Sep 14, 2015 12:38 PM
