CLOCK is dead
Old Nov 22, 2001 | 05:18 PM
DCmax's Avatar
CLOCK is dead
Recently my clock has not switched on when I start my car. Only after hitting the top of it does it only sometimes go on, and when it does, I have to reset it. My mom's 90 SE did this too. Im wondering if there is anything I can re-seat or replace to fix this on my 96 or do I just have to cope with it.
thanks
Old Nov 22, 2001 | 05:21 PM
JAY25's Avatar
This worked for me
thanks
When I first but my car brand new off the lot with 24miles on it no clock either so I told the salesman wuz up with that on a brand new car. They went on ahead and put in a fuse in the fuse box on the left side of your steering wheel. Right there and bam ding and clock came on. Try it and see
Old Nov 22, 2001 | 07:04 PM
party_boy's Avatar
if it doesnt work
you can always buy a watch
Old Nov 22, 2001 | 07:59 PM
Toolrocks's Avatar
if the fuse doesn't fix it - it sounds like a loose wire or connection. Reomove the assembly with the clock and the two vents. It just pulls straigh out. Once you have access behind the clock check the connection - don't just see if it's tight unclip it and make sure there's no corrosion on the terminals. You can also reomove the clock from the console piece if you think something is loose on the clocks circuit board.
shilov
Feb 19, 2024 09:40 PM
t6378tp
Sep 29, 2018 04:27 PM
Matt93SE
Apr 8, 2018 09:23 AM
viperboy
Sep 27, 2015 07:05 PM
markevans999
Sep 10, 2015 04:29 PM
