Quick question
Old May 17, 2009 | 04:56 PM
G4nismo's Avatar
Quick question
sorry to go back to this topic again but....i still haven't been able to unlock my trunk after several methods.
question is, if i unbolted the 2 bolts holding the latch, will that unlock the trunk somehow?
Old May 17, 2009 | 06:27 PM
maxfever1987's Avatar
yes it should since theres only 2 bolts holding the latch secure, so give it a try, the latch will lift up with the trunk if you do this good luck
Old May 17, 2009 | 06:38 PM
G4nismo's Avatar
alright, thanks.
Old May 19, 2009 | 12:51 PM
G4nismo's Avatar
sigh...alright i took it apart and it seems like something is jammed.
i'm guessing the little black knub in the first pic is suppose to move whenever i pull up on the latch. however, it doesn't move at all. when i use the key or the unlock button, it doesn't move. i even tried bangin on the knub w/ something but no luck.
anyone have any ideas what could be wrong? do i need a new latch system?
Old May 19, 2009 | 10:02 PM
jdooley's Avatar
I've never looked at the assembly first hand but in your second picture I see a place where it looks as though there should be a spring installed but I don't see one.
Also, is it possible someone slammed the trunklid down with the latch unexpectedly closed? I have done this on occasion when needing to tie the lid down.
Old May 20, 2009 | 06:54 PM
G4nismo's Avatar
a spring? where would that even go?
i have no idea. i never remember messing w/ the latch ever prior to when this happened.
Old May 20, 2009 | 09:33 PM
jdooley's Avatar
You can see a hole in the 1/4" or so wide bar that runs almost verticaly through the middle of the picture, then to the left and down is something that's hook shaped. It just looks like a spring might belong there but I'm not sure. I'm going to take a quick look in the FSM and then tack an addition a note to the end of this one.
Note: Checked FSM (BT section page 10) and I can clearly see a spring illustrated there. I can't imagine why it wouldn't be there assuming it's never been touched (maybe fatigue?). It does seem unlikely that it would work properly without the spring however.
Old May 21, 2009 | 06:54 AM
HandsonMaxima.'s Avatar
the spring is essential but my bounced open when i hit bumps.
and i had the same problem. my lil black nub that you talked about earlier was worn down and i had to replace it.
Mar 12, 2020 12:06 AM
pears
Sep 18, 2015 05:25 AM
ef9
Buyer/Seller Feedback
Sep 10, 2015 10:13 PM
Johnny9595
Sep 3, 2015 05:18 AM
