Water Pump Question
Old May 31, 2009 | 07:28 AM
Curt's Avatar
Water Pump Question
Does anyone experienced with the Maxima know if there's some sort of tell-tale hint or sympton that the water pump may be on its way out? I recall years ago when inline engines (as opposed to a transverse mounting) with fans, etc. being driven by a belt, and there was a weep hole in the waterpump housing that would drip as a result of the seal and/or bearing starting to fail. Is there any such sympton on the Maxima?
Old May 31, 2009 | 09:16 AM
QNO_A32's Avatar
yep...
Old May 31, 2009 | 01:57 PM
Curt's Avatar
Originally Posted by pmohr
You seem to imply that inline engines can't be mounted transversely (almost) Every FWD 4 banger is an inline, transverse mounted engine.
But assuming you mean RWD vs FWD mounting, almost all water pump setups have a weep hole, it's not like it's a RWD only thing...
The weep hole drain is here:
Also, did you search? I got over 50 relevant hits when searching for 'water pump weep hole'
Instead of trying to guess at a specific cause, and see if your symptoms match it, why not just post up what's happening to your car? Easier diagnosis, there.
1. I appreciate you taking the time to reply to my question. Thank you.
2. One of my other cars is RWD and has a transverse engine, FWIW.
3. Judging from the content of your post, the apparent "attitude" behind it, and the total number of posts you've managed to wrack up, my guess is that you don't have many friends. Something you might just want to invest in some introspection on.
Old May 31, 2009 | 02:40 PM
JAMAICANLOVRBOY's Avatar
when my water pump was bad, it drip coolant after the car gets up to temperature. there is a lil hole in the pump thats designed to drip when the pump is bad. make sure u replace the tensioner
Old May 31, 2009 | 04:50 PM
Merlyn's Avatar
And... I'm out
And my guess is, you know nothing about cars, and care to insult people who help you because they told you that you should have searched prior to asking (as most sections of this forums ask you to do).
And, by the history of pmohr's posts etc... he has helped a lot of maxima.org... what exactly have you done aside from be a complete tool/douche...
Old May 31, 2009 | 05:55 PM
JtzMax's Avatar
Whatchyou say?
all I can say is .... <--- that alone should tell you why you catch an attitude when posting about the 'water pump'. Most every question that can be asked about this subject has, and it's been answered too, multiple times.
Is the car with the transverse mounted RWD a Sabb? lol
Old May 31, 2009 | 06:22 PM
Kevlo911's Avatar
Kevlo for President
Take the help or don't.
Don't ***** about it.
captchaos
Mar 15, 2016 12:18 PM
NERDJUSTBNME
Sep 30, 2015 03:20 PM
RWCreative
Sep 21, 2015 11:01 AM
bumpypickle
Sep 20, 2015 08:22 AM
conansriver
Sep 11, 2015 10:26 AM
