Another Problem with the maxim
Old Nov 25, 2001 | 12:57 AM
Agressive Racin
ok guys. here is the problem tell me if this is normal or not.
well so far the temperature is still off. the front tires make a loud droning noise and the whole car vibrates after 60 mph.
then there is the clicking noise when the car is stopped and you turn the wheel either direction.
then just yesterday when i started the car the oil pressure light would flicker on and off..
what does that mean?
Old Nov 25, 2001 | 12:34 PM
ToYLeT902's Avatar
JET Speed Lab
too much drifting!!!!
Old Nov 25, 2001 | 01:09 PM
MAXIPADMAN's Avatar
Re: Another Problem with the maxim
time to turn in the keys bud. Send her to that special maxima place in the sky.
Old Nov 25, 2001 | 02:56 PM
Victim64's Avatar
Well to answer one of your questions.. NO it is not normal. I noticed in your sig that you just bought the car?? Has this been happing ever since your purchase??
Old Nov 25, 2001 | 03:16 PM
max808's Avatar
tires out of balance or alignment, try rotating tires and see if still happens.
bad cv joint, check for torn boots and check is grease is leaking.
mine flickers once or twice at start up too, could be bad oil pressure sending unit.
litch
123
Jan 4, 2024 07:01 PM
user 11122324
42
Jul 18, 2022 03:35 PM
gavin68
Sep 18, 2021 12:36 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
homewrecker
Sep 24, 2015 07:01 PM
