Radiator Support Replacement (only lower)
Old Jun 18, 2009 | 07:49 PM
i2vicious2's Avatar
SCAMMER DO NOT BUY FROM FOR NOW
I need to know if its very possible to replace only the Lower radiator support instead of replacing the full radiator support. I recently replaced the radiator support but i used a after market one. and after that one broke im just gonna get a OEM radiator support now. but the question i have is can i just replace the lower support where the crossmember bolts to. This is a link to the illustration http://www.courtesyparts.com/maxima-...1897_1900.html
Old Jun 18, 2009 | 08:24 PM
NISSANMAXIMA91's Avatar
Search man. You'll find many threads, Including one by me. It is possible and done numerous times. I got mine from worldpartsexpress.com No problems in the year its been on.
Old Jun 18, 2009 | 08:37 PM
i2vicious2's Avatar
cant find the post. what do i just cut it?
Old Jun 18, 2009 | 09:37 PM
mtrai760's Avatar
'Trynna' is not a word
Your going to need to remove all the spotwelds to get it out, then have someone reweld it back in. Don't go aftermarket, I got mine from DaveB for $180 if I remember right.
Old Jun 18, 2009 | 09:38 PM
try this. has my whole decision process and everything as well as more links.
http://forums.maxima.org/4th-generat...e-support.html
Old Jun 18, 2009 | 10:38 PM
jdooley's Avatar
How easy it is for you to replace just the lower tie bar will depend on how well welded the aftermarket assembly is where the upper and lower parts meet.
When I did mine I found I could not practically remove just the lower support because the OEM had welds I could not get to since I was unwilling to remove my condenser. I to had an aftermarket replacement originally but when I took a closer look at the gauge of the OEM and compared, it was about a 3 to 1 difference!
I ended up using the upper half of the aftermarket one and mated it up with a new OEM lower one I got after noting the difference in thickness. This turned out to be a mistake because my hood, headlights and grill didn't line up properly afterward, even though the fenders did. I lived with it like that for a week then stripped it down again and welded the OEM upper half back in and after that it was both hunky as well as dory .
Old Jun 19, 2009 | 06:28 AM
i2vicious2's Avatar
This is just what i needed to know, i think im just gonna get the full OEM one then, because i no longer have the OEM full radiator support and my hood is slightly off and my grille and headlights to stick out a little. Im calling Dave B now.
CRizz
41
Jun 7, 2021 05:42 AM
vingodine
45
May 21, 2016 12:46 PM
maxinout93
Oct 27, 2015 01:29 PM
homeyclaus
Sep 3, 2015 06:15 PM
classymax420
Aug 6, 2015 06:35 PM
