Alternator ground
Old Jun 28, 2009 | 04:10 PM
maxima-junky's Avatar
Alternator ground
Can someone post a pic of the alternator ground leads to. I can seem to find it. If the alternating current generator is not grounded could that cause the car to draing the battery? I keep switching aternators and the car keeps eating brand new batteries.
Old Jun 28, 2009 | 06:49 PM
pmohr's Avatar
No more Maximas...
The alternator should also ground through the case, I don't imagine a loose or nonexistant ground wire would cause any major issues.
Either way, did you search? I searched 'alternator ground'...
http://forums.maxima.org/4th-generat...check-out.html
http://forums.maxima.org/4th-generat...-location.html
http://forums.maxima.org/4th-generat...lternator.html
And that's just the very first 4 results.
Old Jun 30, 2009 | 04:53 AM
Ok I grounded the alti to the body now the dash lights radio tails and cooling fans don't work. The headligts signals and breaklights still work however.
Old Jun 30, 2009 | 05:54 AM
f550maranello2's Avatar
thats cuz u probably have a shorts somewhere... remove negative lead off battery and see what he current draw is with an ammeter...
Old Jun 30, 2009 | 10:12 AM
TLMNICK's Avatar
The alternator grounds right at the points where its mounted to the motor. Did you check the "alternator" fuse under the hood?
Use a multimeter, and measure the voltage when the car is running vs when it isn't running.
TallTom
57
Oct 14, 2025 05:16 PM
