driver side cv axle wont come out!
Old Jun 30, 2009 | 06:30 PM
gregmaxin's Avatar
I am trying to replace both of my cv axles and i got my passenger cv axle out already and then tried to pull out my drivers side and it wont budge. id tried to pry it out and it still wont budge. Need Advice!
Old Jun 30, 2009 | 06:51 PM
pmohr's Avatar
No more Maximas...
There's nothing to it, just have to pry it out.
What are you using, a screwdriver? Get a proper prybar.
That or you could try beating it out from the passenger side of the diff with a punch...or a screwdriver.
Old Jun 30, 2009 | 07:06 PM
gregmaxin's Avatar
tried to pop it out through the other side with a screw driver. no room to move because of the y pipe and there is a small rod in the tranny that keeps me from seeing the end of the drive axle. i tried prying it out and it wont budge. manual says that it may not be possible to pry off if its an auto tranny.
Old Jun 30, 2009 | 07:10 PM
pmohr's Avatar
No more Maximas...
They pop out quite easily if you have the correct tools.
You can go around the center pin in the diff, but I guess the Y is more your problem.
Yes, the manuals say that, they're incorrect. You just need a good prybar.
One of these type actually work very well:
Not exactly the most proper tool for the job, but it's quite easy.
Old Jun 30, 2009 | 07:17 PM
gregmaxin's Avatar
my pry bar isnt the best. guess ill buy another one and give it a try. thanks for the advice.
Old Jun 30, 2009 | 09:26 PM
jdooley's Avatar
I ended up using a "wrecking bar" on mine which is 3 or 4 times longer than the "wonder bar" that pmohr shows but he's right, with the proper leverage, it will just pop right out.
Old Jun 30, 2009 | 09:29 PM
Invictus01's Avatar
Just hit it really hard with a hammer that's gotta eventually work
Old Jun 30, 2009 | 10:52 PM
ColombianMax's Avatar
Like everyone said, pry bar does wonders. Try having a buddy lightly yanging on the axle while you're prying it from under.. I just pulled both my axles recently as I just got my trans rebuilt and thats all I had to do
matts95max
Apr 23, 2025 10:44 AM
PH98I30
29
Feb 10, 2025 12:03 PM
boomerbrian
Oct 31, 2018 10:25 AM
maximusrising
Sep 2, 2015 09:55 AM
A32goldylocks
Sep 2, 2015 06:39 AM
