Crappy fuel pump or not?
Old Jul 7, 2009 | 04:53 PM
burgundyblues66's Avatar
I have replaced the fuel pump about 5 times already. I replaced it last time with a cheap aftermarket one so I wasn't surprised that it broke. I put a new one in and it still doesn't work. Could it be a problem with the electrical? Does anyone know where the fuel pump relay is? I know the fuse, but I can't see a marked relay.
Old Jul 7, 2009 | 05:25 PM
pmohr's Avatar
No more Maximas...
What exactly is happening to all of these fuel pumps?
It 'doesn't work' as in it isn't getting power? If so, then what could possibly make you think that the solution is replacing the pump itself?
For that matter, what is 'it' when you say 'it doesn't work'? The car doesn't run? The fuel pump doesn't turn on? The fuel pump turns on but doesn't pump fuel? It doesn't crank? Something else?
Driver's side kickpanel, behind the ABS control unit.
If you're looking for a diagnosis (which it appears you are) then we need more information than you've given. So far all you've said is that they 'broke' (which means absolutely nothing). Nothing about checking power, harnesses, symptoms, initial causes, etc.
Also, you should fill out your profile with what year you own; wiring can be very different from year to year, the last thing you'd want is an assumption that ruined a part because you neglected to fill out your profile.
Old Jul 7, 2009 | 05:33 PM
ok, well ill check the wiring stuff tonight and let you know.
but, to get to the fuel pump relay do you have to take off the ABS control unit? just asking because that seems like a lot of work in itself
Old Jul 7, 2009 | 06:04 PM
pmohr's Avatar
No more Maximas...
Yes, you have to remove the ABS computer. What seems so hard about it? It's one or two 10mm head bolts, and a harness connector.
And again, WHAT is happening to the fuel pumps? We can't help if you don't give any information.
Old Jul 7, 2009 | 10:33 PM
Thanks a ton for being so helpful, I will check the relay tomorrow.
For now, I checked the voltage going to the fuel pump with a volt meter. Since my car is doesn't start, I took the voltage with the ignition on and the voltage when the starter is turning the engine over.
Voltage at turn-on is 1v
Voltage when turning over is 9v
This seems low to me, it seems like it should be 12v. Also, when I connected the "broken" fuel pump directly to the battery with two wires it works fine, which leads me to believe that isn't the problem. Is this voltage normal?
Old Jul 7, 2009 | 10:43 PM
pmohr's Avatar
No more Maximas...
Depends, what voltage is your battery at?
Assuming you still have a '96 (because your profile is still blank), you've got the whole FPCM crap.
You're getting nowhere near what you should be. Could be a bad relay, connection somewhere, the FPCM itself, the ECU may be commanding the FPCM incorrectly, etc.
FWIW 'turning over' == starting, not cranking.
Old Jul 8, 2009 | 01:55 PM
mahanddeem's Avatar
Another flamed fela
Old Jul 12, 2009 | 07:20 PM
well, i just replaced the relay with a new one and it still doesnt work. 1v when you turn the key and 9v when engine is cranking. the plug next to the fuel pump one (fuel guage wire) gets 12v, so i dont think its the battery. fuel pump should work too, don't really know what to do....
Old Jul 12, 2009 | 07:21 PM
pmohr's Avatar
No more Maximas...
Does the relay get B+, or those low voltages you're getting at the pump?
You need to start tracing back to where it's no longer getting battery voltage.
Old Jul 12, 2009 | 07:33 PM
what do you mean B+?
Old Jul 12, 2009 | 07:34 PM
oh nevermind, those are the voltages at the pump, under the back seat
Old Jul 12, 2009 | 07:35 PM
pmohr's Avatar
No more Maximas...
B+ == battery voltage.
Old Jul 12, 2009 | 07:50 PM
battery voltage is 12, as is the fuel level connector, just the fuel pump connector is 9 when cranking. something aint right...
Old Jul 12, 2009 | 07:53 PM
pmohr's Avatar
No more Maximas...
...what?
Okay, again. Does the relay get B+ or the low voltage?
As I said, you need to determine WHERE your voltage drop is happening.
Old Jul 12, 2009 | 11:25 PM
Child_uv_KoRn's Avatar
Bad *** Newb
Wire it direct and forget about it?
jmlee44
Oct 2, 2022 02:13 PM
Miket2006
Mar 1, 2021 03:55 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
