SLIP, ABS, TCS dash lights always lit
Old Jul 11, 2009 | 02:14 PM
progrocker's Avatar
Since spinning my wheels in the snow last winter my SLIP and ABS dash lights are always lit. Also the Traction control is stuck in the OFF position. If I disconnect the battery for a period of time will these lights reset? If not any suggestions? Thanks all.
Old Jul 11, 2009 | 02:37 PM
VQrebuild96's Avatar
4th gen with traction control?
Old Jul 11, 2009 | 02:48 PM
modenaf1's Avatar
I would start by checking the fuses. After that, I would look in the 1999 FSM. I believe there is a diagnostic procedure to get it to flash a code.
Some 99's got it.
Old Jul 11, 2009 | 03:21 PM
FallenOne's Avatar
there is, i would also check to make sure that your grounds and battery terminals are sufficiently tight, and that the ABS sensors are not dirty or damaged.
Old Jul 11, 2009 | 03:51 PM
pmohr's Avatar
No more Maximas...
Have you not tried this yet? It's been what, 7 months since the wintertime? Disconnecting a battery cable takes 10 seconds...
Old Jul 11, 2009 | 05:11 PM
progrocker's Avatar
First thing I did was disconnect the battery cable for a couple of minutes. My question asked if it had to be disconnected for some period of time for a reset. Try completely understanding a question before offering up a condescending half assed remark genius.
Old Jul 11, 2009 | 05:13 PM
pmohr's Avatar
No more Maximas...
If you're looking for help, that's not the way to talk.
Did you mention that you had already disconnected the battery? ...no, I didn't think so.
I understood the question well enough, and I've actually got the answer as well.
Anyway, I'll move along now.
Old Aug 23, 2009 | 12:36 PM
Darkstonian's Avatar
Well before you do, I'd like the answer, cause I'm having the same problem, 5th gen though. If you don't want to share with the aforementioned, shoot me a PM plz. Thanks
Old Aug 23, 2009 | 04:45 PM
max ride 41's Avatar
wow pmohr, it just dawned on me that your like the chef ramsey of the maxima forums. i can imagine that you'd be screaming your replys at these guys if you had your own show.
mvm062
Nov 30, 2020 09:00 AM
MaxLife17
Jun 27, 2019 01:37 PM
MaxLife17
Sep 8, 2015 02:36 PM
maximusrising
Sep 2, 2015 09:55 AM
