1999 Compression Test Results
Did a test, and this is what I got:
(BTW engine was just below operating temp because we had to disassemble the coils an plugs and all)
210 210 210
205 210 195
Is this alright? Maybe a bit of carbon buildup but not bad?
And if I had a bent rod then it would probably be lower than 195? Because that's the cylinder that had hydro locked on me..
210 210 210
205 210 195
See I hydro locked the one that reads 195psi, because I had a faulty fuel injector that was basically pouring gasoline into the cylinder(lost a small O-ring)...and whenever I tried to start it went "CLUNK" so I hope that nothing internally got damaged...I had it first towed to the dealership, and the douchebags at the dealership started it and those ******** may have ****ed it up big time; You'd think that they would know that it was hydro locked and to at least first relieve the cylinder of the fluid built up instaed of just ****ing persisting to start it until it goes ..
Now when I have it running, it's either smooth or rough, So I did the compression test to maybe indicate damage inside.
Shadyonedeath:
1 remove all spark plugs after warming engine to normal operating temps and
2 relieve fuel pressure
3 connect the compression reader to where the plugs would go
4 crank engine to get each cylinder compression
Now when I have it running, it's either smooth or rough, So I did the compression test to maybe indicate damage inside.Shadyonedeath:
Yea it involves buying a compression gauge. I think they run 20 bucks at AdvanceAuto.
http://www.geocities.com/dsmgrrrl/FAQs/compression.htm
There's more to it than that. You need to block the throttle WOT, and preferably have it on a battery charger. And not only relieve the fuel pressure, but you want to disable the pump (or injectors) as well.
If you were concerned about these numbers, did you search for others?
http://forums.maxima.org/5th-generat...00-maxima.html
http://forums.maxima.org/4th-generat...plug-coil.html
http://forums.maxima.org/5th-generat...2k-maxima.html
http://forums.maxima.org/general-max...e-results.html
...etc.
Basically if you're concerned about the slightly high readings, run some engine cleaners, see what happens.
litch
123
Jan 4, 2024 07:01 PM
tarun900
19
Dec 20, 2021 06:57 PM
mkaresh
Mar 12, 2018 06:48 PM
add that and pulling the pump fuse too
If I had a bent rod, would I def know it?
