Battery Issue after radio install
Old Jul 13, 2009 | 07:45 AM
nissanfreak's Avatar
Hello guys I finally got around to installing my 06 pathfinder radio this weekend. And like everyone says to do, I jumped the K and D wires together. However after doing this its like my battery gets drained. At first I thought it was the battery so I changed it and used another battery from my other car. And this morning when I went to crank up my car my battery was dead again. Has anyone else had this problem after doing this install? Thanks in advance!
Old Jul 13, 2009 | 11:03 AM
pmohr's Avatar
No more Maximas...
Have you done a parasitic drain test yet?
What are the wire colors you spliced together? Are you sure you didn't connect the constant B+ wire to the amp turn on, instead of a switched B+?
Old Jul 13, 2009 | 12:09 PM
If your looking into the back of the radio, I connected the top right of the right plug to the top left with the left plug using a piece of wire. The wire colors were blue and green/white. Any ideas?
Old Jul 13, 2009 | 12:13 PM
pmohr's Avatar
No more Maximas...
You should fill out your profile, had to search through 2 or 3 pages of your threads just to find out you have a '99. Only takes a few seconds to fill out, and it helps others help you.
Looks like that's wired properly.
Again, parasitic drain test?
Old Jul 13, 2009 | 12:16 PM
Ok I will. I wonder if a 99 SE-Limited would be wired any differently? How do I do a parasitic drain test?
Old Jul 13, 2009 | 12:17 PM
pmohr's Avatar
No more Maximas...
Extremely unlikely.
http://www.wikihow.com/Find-a-Parasitic-Battery-Drain
Old Jul 13, 2009 | 12:30 PM
I guess whats weird is that all this started after I installed the radio.
Old Jul 14, 2009 | 07:54 AM
Ok I figured it out. It turns out that my battery terminals were so corroded that I wasnt getting a good connection with my battery. I think im going to get an optima dry cell battery so that I dont have to worry about corrosion anymore
Old Jul 15, 2009 | 04:49 AM
Ringo1965's Avatar
1997 Nissan Maxima SE
Kind of strange that you did not notice the corrosion, when you swapped out the battery from your other car
Old Jul 15, 2009 | 08:29 PM
new maxi owner's Avatar
why spend 150$ on a optima yellow top, when you can just spend 2.50$ on a box of baking soda mix it with water and dump it on the terminals, and clean em.
Old Jul 15, 2009 | 10:38 PM
96WhiteMaxima's Avatar
Or even cheaper, $1 for a can of coke, clean and refreshing.
JRod28
Dec 29, 2023 09:56 PM
Viralkill
Aug 17, 2015 10:54 AM
Viralkill
Aug 16, 2015 05:09 PM
Superbform
Aug 11, 2015 08:10 PM
