Open ended Engine vacuum line- normal?
Old Jul 15, 2009 | 03:23 AM
edwardh1's Avatar
1999 engine - I had the throttle body cleaned by a good repair shop. At home here I looked under the hood and noticed (what may have existed before the repair) an open ended vacuum line. It is between the positive post on the battery, and the battery side of the front valve cover.
What is unusual about it is that the open end of the hose is formed in a hook, or short 90 degree turn of about one inch. looks made that way.
Is this normal? the line runs from the open hook end back toward the valve cover then goes down into the engine area.
Old Jul 15, 2009 | 03:47 AM
shanegalla's Avatar
yeah i think that is the breather hose for the vacuum system. I have it on my 96.
Old Jul 15, 2009 | 04:34 AM
pmohr's Avatar
No more Maximas...
It's normal. Did you actually follow it down? It's a trans breather hose.
FWIW this has come up time and time again, if you search 'open vacuum hose' or similar, you'll get a lot of results of people asking this question.
A breather hose for the 'vacuum system'? All that would be is a giant vac leak.
Old Jul 15, 2009 | 08:18 AM
edwardh1's Avatar
Thanks- I should have searched,
I did just search but did not get much..
Old Jul 15, 2009 | 12:26 PM
asand1's Avatar
I have it on my 96.
Old Jul 15, 2009 | 11:05 PM
96i30azn's Avatar
an unplugged vacuum hose will make your car idle rough
Old Jul 16, 2009 | 04:55 AM
edwardh1's Avatar
so true- car runs fine thats why I asked if the open line was made that way at the factory
cruce91
Sep 20, 2015 10:23 AM
lowpost99
22
Sep 2, 2015 04:38 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
N2deep
Aug 16, 2015 08:30 PM
