Air Conditioner / Heater Switch Malfunctioning
Old Nov 6, 2000 | 01:32 PM
Wadester
Hi everyone!
I have a 96 Maxima SE, and all of a sudden, the Heater/AC switch stopped operating in positions 1, 2 and 3. The 4th position works great, but I may not want the heat or air on full blast all the time. Occasionally the light goes out behind the switch also, but I can make it come back on by tapping it, most of the time. I wonder if this is a common problem, because my father has a 95 Maxima, and his doesn’t work either; He is lucky though… only the first position on his stopped working. The interesting thing here is this… lets say that I have the AC switch pushed in, and turn the dial to position 1 2 or 3, I can hear the compressor turn on, so I see it is working somewhat, just not turning the fan on. Anyone else run into this? If so, what did you do to fix it??
Also, thank you to everyone who posted information on changing the gauge lights! I put some blue lights in yesterday, and it looks great!! I wonder if there is a way to change the lighting for the heater/ac unit, so it all matches up! Has anyone done this yet?
Thanks in advance for the help! What a great list!
Wade
Old Nov 6, 2000 | 02:42 PM
Daniel B. Martin's Avatar
Originally posted by Wadester
Hi everyone!
I have a 96 Maxima SE, and all of a sudden, the Heater/AC switch stopped operating in positions 1, 2 and 3. The 4th position works great, but I may not want the heat or air on full blast all the time. ... ...
There is a resistor assembly mounted on the air duct close to the blower
motor. That part has failed. It is used to control fan speeds 1, 2, and
3. Speed 4 is the maximum blower motor speed, so no resistors are
involved. Replacing the resistor assembly is something the home mechanic
can do. The only tool needed is a Phillips head screwdriver.
The Haynes manual has a good photo of this part on page 3-8.
Old Nov 6, 2000 | 03:58 PM
Wadester
Thank You!!
Excellent! Thank you very much for the information! Sounds easy enough.
-Wade
1996 SuperBlack Max
5 Speed
Walnut Trim
Tootsie roll stain under the right seat from the previous owner.
1985 300ZX - Street Modified
Old Nov 7, 2000 | 01:18 AM
Che's Avatar
Che
man
i thought i was the only one......will have to replace this weekend.
Old Nov 7, 2000 | 08:22 AM
Eric L.'s Avatar
Very common Nissan problem. Everyone I know who has a Nissan has had their HVAC fan resistors fail.
Basically, the default position for the resistor is "no resistance" which amounts to the fan at 4.
Old Nov 11, 2000 | 02:22 AM
Che's Avatar
Che
this may seem obvious
but where is the resistor assembly for the blower motor located??
Old Nov 11, 2000 | 07:42 AM
Re: this may seem obvious
As stated previously, it is in the air duct close to the blower motor. Get your head under the dashboard on the passenger side. The blower motor is in plain view. Notice the bundle of wires leading away from the blower motor. It leads to the resistor assembly, situated only two to three inches from the blower motor. Disconnect the electrical connector. Remove two Phillips head screws and the resistor assembly falls into your hand.
Famous saying: one picture is worth a thousand words. The Haynes manual has a good picture on page 3-8. You can buy this book at any large bookstore (Barnes & Noble, BookStar, Borders) or auto parts store (AutoZone, etc.). You may find it on the shelf at your local public library.
Old Nov 18, 2000 | 12:52 AM
Che's Avatar
Che
coolio
thanks daniel.
Miket2006
Mar 1, 2021 03:55 AM
AaronL
Aug 8, 2020 10:31 AM
howardis
Dec 11, 2019 06:10 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
lrb6805
Sep 24, 2015 05:03 PM
