Too much back pressure,Hindering Performance,Sh*tty exhaust work,All of the above ?
Jul 18, 2009 | 10:57 PM
So i finally have my car up to factory par now.
new belts, sensors, hoses, t-stat, tires, plugs etc.
Looking to make a bit more power or at
least opening up the intake/exhaust breathing of the motor.
The headers don't seem that restrictive but the y pipe def is getting replaced with a cattman or warpspeed.But my question is..
I was doing some suspension work and noticed this. . . . . .
Everything behind the 2nd o2 sensor has been replaced within the last year.But whoever did it, Smashed down on the piping after the resonator.
Im sure this is going to cause me some unwanted back pressure but is it worth it to buy a cat back from cattman to replace this,....or is this not a big deal since im staying n/a and prolly wont exceed an additional 20-30 hp in my gains ?
Jul 18, 2009 | 11:36 PM
i wouldn't be worried so much about that pipe as i would the body. one more winter and you can power that car flintstone style.
Jul 19, 2009 | 08:26 AM
Quote: i wouldn't be worried so much about that pipe as i would the body. one more winter and you can power that car flintstone style.
Nah..The maxima wont ever see snow.
I have a sentra for the winters season.
Most of it it just surface rust anyways..
None of it is real weak.
pmohr:
Sorry I meant exhaust manifold.
They dont look that restrictive.
and the 20-30 is just a guesstimate with a
y-pipe , k & n cai and a cattman underdriven pulley.
Thats what Ive gotten on similar cars i've modded.
Is there an aftermarket brace i can add
to the car that takes the place of that oem one im missing ?
Jul 19, 2009 | 12:38 PM
Ohh..I see, Well if thats all it does then i'll just make one myself.
I have tons of extra 1/4" flat bar laying around.
I saw some under chassis brace in the newer threads..Didnt really look into it but thought it was mounted in the back of the chassis somewhere..Must be a front brace.
Jul 21, 2009 | 12:23 AM
If you want to fix backpressure.
Headers + Cat-back is the solution. Stock exhaust manifolds are one of the most restrictive parts of a Maxima.
Jul 21, 2009 | 06:17 AM
sorry for asking out of topic...
I bought header and y pipe weeks ago and they give me the 'given' gasket. From what I've read, that we need to use the OEM gasket. Do I need to replace the OEM exhaust manifold gasket with a new one (OEM gasket) or we just can use the old one?
Jul 21, 2009 | 12:23 PM
Quote: Not on the A32...
So..Whats the most restrictive part then ?
Jul 21, 2009 | 02:02 PM
Quote: The stock Y.
I support this message. Say Slow_Yota, have you ever actually taken a look at the Stock Y? Its got some realy freaky bends before the Flex Pipe that were designed to restrict exhaust flow to keep the power band in the lower trq ranges.
Jul 21, 2009 | 02:17 PM
http://forums.maxima.org/4th-generat...d-new-one.html
Jul 21, 2009 | 03:53 PM
the man is right.... stock exhaust manifolds are fine...
the stock y pipe is restrictive after like 3k rpms...
Jul 21, 2009 | 10:39 PM
Ya i think the Y pipe is a def mod to come pretty soon.
maybe even a B if i can get one.
Thanks for the info everyone =]
Jul 22, 2009 | 03:22 AM
Quote: You can use the old one, assuming it isn't damaged.
How di I know if it isn't damaged?
Jul 22, 2009 | 08:48 AM
Quote: How di I know if it isn't damaged?
lol, ehh ha. Hmm..You look at it.
Jul 22, 2009 | 08:57 PM
Quote: lol, ehh ha. Hmm..You look at it.
I guess it is multi layer steel gasket... I don't think so it can be damaged except we broke them...
So I don't need to buy a new gasket right? (it would save me for $90)
Jul 22, 2009 | 09:03 PM
Quote: I guess it is multi layer steel gasket... I don't think so it can be damaged except we broke them...
If the three-layer steel gasket is installed currently, there's a chance it has warped over time and will not seal correctly upon reinstallation. Happened to me, I had a terrible exhaust leak no matter what I did to the gasket and I had to buy a new one.
Jul 22, 2009 | 09:20 PM
Quote: Again, as I clearly said before:
hopefully my gasket still in good condition...
anyway, thanks for your answer
Quote: If the three-layer steel gasket is installed currently, there's a chance it has warped over time and will not seal correctly upon reinstallation. Happened to me, I had a terrible exhaust leak no matter what I did to the gasket and I had to buy a new one.
oh man... If I should bought a new gasket then I will rather buy a full set engine gasket since I have a plan to overhaul my engine next year...
Jul 22, 2009 | 09:35 PM
to the OP, don't even waste your time making/fitting that exhaust brace. if you ever do upgrade your b-pipe, say to a 2.5'', the brace won't even fit. the ypipe is so restrictive due to the 2 large precats on the ypipe.
IMO, go aftermarket y-pipe, HFC, 00vi/mevi (00vi preferably), 2.5'' b-pipe.
Jul 23, 2009 | 01:41 PM
whats oovi ?
Jul 23, 2009 | 05:22 PM
Quote: Not oovi, 00VI. And seriously?
Did you search? Or look at the glossary in the stickies? Or look at the stickies in AM?
Yea I've looked over almost all of the how to's and stickys..
Some i didn't i'll admit but only the ones that didn't concern me
And I've never heard of this "OOVI".
Jul 23, 2009 | 06:13 PM
@ pmohr
Jul 23, 2009 | 06:14 PM
oovi, mevie, movie..- pa toobee..Whatever.
Seems like a lot of work for minimal gains.
Thanks but i think i'll just do the exhaust and a K & N CAI.
Jul 23, 2009 | 06:48 PM
Im going with the y pipe mainly because my flex is leaking and makes the car sound like crap..the extra hp is just a nice bonus.
the CAI prolly wont net much hp but gives it a nice added tone to it.
And there is no way a variable intake will give an
n/a motor with minor bolts on 50 hp.
on a boosted motor..Sure.
but come on..190 from the stock motor.
25 from clearing out the exhaust and CAI.
So we're at 215, Show me a dyno sheet that proves a
00vi install will get me 265 hp at the fly and
i'll get one off of ebay tonight.
Jul 23, 2009 | 07:00 PM
I'm done here, it's obvious that with some people, there's absolutely no point in trying to educate them; they find new and interesting ways to fail, every single time.
Jul 23, 2009 | 07:09 PM
The usim peaks at 170 hp, The 00vi peaks at 190..and like you said the extra 20 that you would get isnt even streetable, and i do get the "ricer math" But you said the 00vi would net 50 hp..Not that the intake mani, exhaust and cai would net 50..I agree with that..Im sure thats do-able, Not saying that it wouldt make more power than the usim..I was under the impression that you were trying convince me that a the 00vi would net me 50 hp a side from the exhaust and cai gains.
Jul 23, 2009 | 07:24 PM
You seem upset..Cool down, It'll be ok.
I understand ..Really.
I guess I just dont care that much to change it.
And yes i can see that the power curve doesn't dip nearly as soon as the usim does.
But this is my DD, I dont redline the motor or go above speed limit [most of the time]
Im saying that I prolly wouldt use the improved power curve you get when you install a 00vi..and if i want to race or get thrown in the back of my seat, I'll just break out my 300.So thanks for the info, But ..I think 00vi is a no go for me.
Jul 23, 2009 | 07:37 PM
Quote: The usim peaks at 170 hp, The 00vi peaks at 190..and like you said the extra 20 that you would get isnt even streetable, and i do get the "ricer math" But you said the 00vi would net 50 hp..Not that the intake mani, exhaust and cai would net 50..I agree with that..Im sure thats do-able, Not saying that it wouldt make more power than the usim..I was under the impression that you were trying convince me that a the 00vi would net me 50 hp a side from the exhaust and cai gains.
If you granny shift, it won't help you. The 00VI starts to make significantly more power above 5000 rpm. If you get a 7500 rpm rev limiter, then the 00VI gives you great top end power. You can keep the motor in its best powerband for longer, and the car will be significantly quicker.
I don't see how power added above 5000 rpm isn't "streetable". It's pretty simple. Instead of upshifting at 5000 rpm, upshift at 7000 rpm. If you have an 00VI and an extended rev limiter, your car will be much faster, without sacrificing any driveability.
If, as you say, you don't redline the motor, then may I ask why you are bothering wasting money on performance upgrades? It's a well-documented fact that most gasoline motors make more power at higher RPMs. If you're driving along and saying "Hey, cruising at 3000 rpm is great, but I wish I had more horsepower". There's an easy solution. Downshift, and rev it higher. You will instantly have significantly more horsepower, for free.
If you're not using the power you have now, then why do you need more?
Jul 23, 2009 | 08:06 PM
Quote: If you granny shift, it won't help you. The 00VI starts to make significantly more power above 5000 rpm. If you get a 7500 rpm rev limiter, then the 00VI gives you great top end power. You can keep the motor in its best powerband for longer, and the car will be significantly quicker.
Then how can we extended rev limiter? I have put an piggyback computer (Dastek Unichip) on my car. It still had a redline on 6700rpm. Is still getting more power at the 7500rpm? Do we need to do engine component balance before we extended rev limiter?
FYI : my car is an auto and have a MEVI.
Jul 23, 2009 | 08:12 PM
oh my.. 20 to 30? ehh, try like 5-10 and thats how mine looks the same as yours but the input output press is a science so you can free it up all you want but no back pressure means there wouldnt be enough intake, so your better off upgrading to a catback after you get a y-pipe
Jul 23, 2009 | 08:37 PM
Quote: Then how can we extended rev limiter? I have put an piggyback computer (Dastek Unichip) on my car. It still had a redline on 6700rpm. Is still getting more power at the 7500rpm? Do we need to do engine component balance before we extended rev limiter?
Most of the people I've seen have JWT ECUs with extended rev limiters, but I'd imagine there are other ways.
Jul 23, 2009 | 08:44 PM
Well first off i have an auto so =/
Anywhoos..
Like i had said i have a flex thats leaking and faling a part at the seems..So i need to replace that.Might as well upgrade to a free flowing y pipe.
I dont beat on my dd's, thats what the track car is for...
But it is nice to have the option to have the extra power if i do need it at some point.Like if someone were to pull out in front of me or i need to get out of traffic or whatever...Its just nice to have a bit more than the average joe i guess.
But mostly, Im replacing things that need replaced and upgrading them at the same time..My intake mani isnt damged and i just cant justify spending $300/time/labor on something that i'll barely use.
Jul 23, 2009 | 09:58 PM
Quote: Most of the people I've seen have JWT ECUs with extended rev limiters, but I'd imagine there are other ways.
hope so my local dealer can extend rev limiter without change my ecu
Jul 23, 2009 | 10:24 PM
Quote: Well first off i have an auto so =/
Anywhoos..
on something that you'll barely use?
what are you talking about? you use your IM every time you crank up your car.
plus, its been dyno proven that the 00vi is far superior than the stock USIM.
the usim just loses breath in the upper rpms whereas the 00vi doesn't hence the variable induction system with the rotary valve. same goes for the mevi but just under the 00vi. the 00vi is also comprised of plastic so better heat dissipation and no need for a plenum spacer.
Jul 23, 2009 | 11:23 PM
Don't forget that the 00vi increases torque in the lower RPM range over the standard usim (what does usim stand for anyway? i thought the maxima was a japanese car)
Jul 24, 2009 | 06:36 AM
lol..of course i would "use" the manifold but i would't take all that much advantage of it.I hardly ever take my car over the 4500-5000 rpms.
I like this car a lot and i've broke enough of them to know what to do and what not to do to keep it around.
And i read in one of the threads that pmohr listed that one of the guys had heat soak probs with the 00vi and that his butterflies wouldt work correctly.
That scares me off as well.
Jul 24, 2009 | 07:52 AM
you can try mevi, based on logical I think should be more durable compared to 00VI because it more simple...
and another advantage, from what I've seen plastic manifold not as durable as aluminium intake when you put FI on your engine. I ever seen a car with a broken plastic manifold when he put high boost...
CMIIW
Jul 24, 2009 | 09:39 AM
Quote: lol..of course i would "use" the manifold but i would't take all that much advantage of it.I hardly ever take my car over the 4500-5000 rpms.
alright well thats fine. i thought you mentioned you wanted more power and just thought i throw the 00vi out there.
also, your scared about the 00vi due to 1 report? it'll have better heat dissipation than the usim and the guy prob didn't even pre-fix his VIAS (jb weld) prior to installation.
