Gear Oil (MT only)
Old Jul 25, 2009 | 09:49 AM
Q8BallMAXIMA's Avatar
Gear Oil (MT only)
My 98 MAX SE has 169k on it and from the previous owners records, they never changed the gear oil in the gear box. In the owners manual it suggests 100k to be done.
Does anyone have any suggestions on gear oil for the gearbox and how difficult is it to change?
I like working on my own car and want to change it myself (cheaper and more satisfying to do myself).
Thank you for any suggestions and help.
Old Jul 25, 2009 | 10:07 AM
Sounbwoy's Avatar
I use Redline MT-90.
http://www.redlineoil.com/products_g...7&categoryID=7
Old Jul 25, 2009 | 10:36 AM
f550maranello2's Avatar
Originally Posted by Sounbwoy
i just put in MT-90 in my trans yesterday.. it amazing how good it shifts now.. before it was a little difficult to downshift form 3rd to 2nd but now its like butter...
get it its really good..
Old Jul 25, 2009 | 10:53 AM
pmohr's Avatar
No more Maximas...
Did you search, or try to read up on this yet?
Did you check the appropriate subforum?
http://forums.maxima.org/fluids-lubr...-gear-oil.html
Old Jul 25, 2009 | 11:15 AM
DAVE Sz's Avatar
Hooooooonda.....
Just wait for the temps to drop, it'll get notchy. That's why I got 1qt of redline MTL to put in along with 3+ qts of mt-90...
Old Jul 25, 2009 | 11:57 AM
cobradb's Avatar
trans lube for manual
Redline mt-90
Old Jul 25, 2009 | 03:23 PM
tht98maxkid's Avatar
Its xtremely easy if yu have a funnel.. but its nothing yu should pay something to do
Old Jul 25, 2009 | 06:00 PM
nafddur's Avatar
Yep, I remember it being pretty easy to both drain and refill (using a funnel with a flexible extension) back in 2000 when I did mine. My 95 SE had 120K miles at the time, and was still on the original trans. fluid.
Back then, I had to search to find GL-4, but finally found SAE 85W90 GL-4 Hypoid Gear Oil made by Sta-Lube. I bought a gallon ($8.49) and 1 qt. ($2.49) at a Napa store in SE MA, and had 1/2 qt. left over.
Now, 9 years later and at 206K miles, I think it's time to change the trans. oil again.
Old Jul 25, 2009 | 06:47 PM
ColombianMax's Avatar
When I did my clutch last year I put in Royal Purple cuz I wasnt able to find Redline locally and then when people found out I used Royal Purple instead of Redline they all started telling how I should've gone with Redline bla bla bla so this time I got my trans rebuilt, I searched and found MT-90 locally for 10-12 bucks a quart at a few shops. Cant quite feel a difference but I guess we'll find out in the cold season... Is there something else I should've tossed in there beside MT90?
Old Jul 26, 2009 | 05:58 AM
Thanks everyone for the help. I should definitely be able to do this procedure myself.
Old Jul 26, 2009 | 06:26 AM
clp2112's Avatar
Gear oil
I've used this Amsoil on several Nissan and Toyota transmissions. Really works well .Specifically designed for manual gear boxes .
http://www.amsoil.com/storefront/mtg.aspx
Old Jul 26, 2009 | 07:58 AM
RA030726's Avatar
I'm nutty for Nissans
Ive run mt 90, mt 90/mtl mix, mtg, and napa sta-lube. they all worked fine except sta lube which is like molasses and sucks big time in cold climates.
Anyhow dont remove the neutral safety switch to drain through. You will break it or loose a part. Use the drain plug at the back of the tranny near the shift rod. Its hard to get to and easy to miss but its the best way.
user 11122324
42
Jul 18, 2022 03:35 PM
mclasser
22
Nov 12, 2020 01:58 PM
05RLS2
Apr 14, 2016 11:49 AM
