just a quick question on lower ball joint removal
Old Jul 27, 2009 | 10:55 AM
kevinoseguera99's Avatar
going to take my control arms off and install some energy suspension black control arm bushing, the old stock ones are really worn out. while its out, i was thinking of replacing the lower ball joints too. ive searched here and i know it can be done. but alot of people take it to a machine shop and have them pressed. but if i dont do that, i just wanna confirm about using this tool down here. can rent it at autozone to press the olds ones out and the new ones in.
Old Jul 27, 2009 | 11:05 AM
1chewabacha1's Avatar
For getting it out, I personally used a torch and hammer. Luckily my bro and I had just purchased a press so that's what we used to press it in (Use lube for smooth entry). But I'm sure you can come up with a ghetto press concotion.
IE. before the press I had to get my ES motor mount Bushings into the motor mounts, I jacked up a car and used its weight coming down on a wooden block as a press (^_^).
I'm sure you could use a hammer to put it back in too, but I wouldn't wanna risk damaging it.
Old Jul 27, 2009 | 11:22 AM
jlockhart_715's Avatar
I used that tool it worked just fine, just read the directions I ruined a ball joint putting it back in because i did not use the press sleeves correctly
Old Jul 27, 2009 | 11:26 AM
thanks guys, thats all i needed to know
Old Jul 27, 2009 | 02:24 PM
XeroX's Avatar
Hella internets
I did the EXACT same thing for my ES motor mounts hahaha
I have also used Crank pulley removers to press out ball joints...that sometime works...just an idea...
maxocar
Aug 21, 2015 12:57 AM
jhontelj
Aug 17, 2015 04:07 AM
soon2ownmax
Aug 13, 2015 02:19 PM
Flores94
Aug 11, 2015 12:53 PM
classymax420
Aug 6, 2015 06:35 PM
