Axle Popped back out!!
Old Jul 30, 2009 | 08:53 PM
DJSARGE's Avatar
replaced a passenger side axle along with the control arm and after 2 days it popped back out while i was driving... im so afraid it will happen again so i wont even go on the highway... has this happened to anyone before?? and what are the possible causes of it popping back out???? plzzzz i've searched the entire internet
Old Jul 30, 2009 | 09:37 PM
fastmax24's Avatar
where did it pop out of the hub or tranny..
make sure it the axle nut is on there tight with a cotter pin
Old Jul 30, 2009 | 09:46 PM
asand1's Avatar
Did the inner joint desperate, or did the joint pop out of the trans.? I read another thread here about 3 NEW shafts coming apart at the inner joint. I believe they were Autozone pieces. Seems they did not install the snap innermost snap-ring.
Old Jul 30, 2009 | 10:05 PM
pmohr's Avatar
No more Maximas...
You seem to imply that it popped out of the trans, at least that's what I'm getting from it.
You did install the three bearing retainer bolts, correct? Other than the inner joint collapsing on itself, that's the only way for the passenger side axle to come away from the trans.
Old Jul 30, 2009 | 10:30 PM
Leo_Koneval's Avatar
Wow, that sucks.
Do you have any pictures or video? I think a picture of the damage would be a great thing to refer to for diagnostic purposes.
Old Jul 31, 2009 | 08:38 AM
DJSARGE's Avatar
ok it popped out of the tranny while i was driving... and i'm not sure of the bolts u r referring to bcuz there were no bolts when i took it out the original ( on the tranny side) i put back everything in the reverse order i took em out and tapped in the axle with a hammer n wood. tried turning the axle with my hand to make sure the cogs were locked in good n all. i'll have pics within a few hours
Old Jul 31, 2009 | 08:44 AM
DJSARGE's Avatar
just to make sure we're on the same page... i have an i30t
Old Jul 31, 2009 | 08:53 AM
99BlackMaxMS's Avatar
There is a support bracket for the passenger axle (looks like a triangle) that you need to put the axle through, and then use 3 14mm (iirc) bolts to secure the axle to the car. It is about halfway between the hub and the transmission. If you didn't put those three bolts in, that is most likely why your axle keeps popping out.
Old Jul 31, 2009 | 08:58 AM
96i30azn's Avatar
I thought you replaced the passenger side axle... Am I wrong to think that the tranny is on the driver side?
Old Jul 31, 2009 | 09:00 AM
modenaf1's Avatar
Yup, as everyone else said. Unlike the drivers side, with those three bolts off on the passenger side, it is extremely easy to separate the axle from the transmission. With out those bolts, it is very likely the axle will come out of the transmission at some point.
Old Jul 31, 2009 | 01:46 PM
RA030726's Avatar
I'm nutty for Nissans
this thread is full of fail.
Old Jul 31, 2009 | 02:49 PM
f550maranello2's Avatar
guy has his drivers and passenger side mixed up..
Old Aug 1, 2009 | 03:38 AM
dgeesaman's Avatar
Maintenance Monster
Or he has no passenger support bracket, if it's even possible to drive like that.
Old Aug 5, 2009 | 12:14 PM
Augustus Maximus's Avatar
How about a few weeks.
JRod28
Dec 29, 2023 09:56 PM
CorollaULEV
30
Aug 9, 2021 08:11 PM
boomerbrian
Nov 8, 2015 05:10 PM
seesole
Aug 26, 2015 11:22 AM
FanaticMadMax
Aug 10, 2015 08:55 PM
