Squealing like a pig
Old Aug 2, 2009 | 05:52 AM
Galager's Avatar
My alternator blew and since the mechanic was already gonna be in there, I had him change the belts with OEM Nissan belts. Now when I start the car, it squeals like a pig if the AC is on. If I turn off the AC, it stopped and when I turned it back on, it was fine. Any idea why that might happen?
Old Aug 2, 2009 | 07:51 AM
Jayson89NYC's Avatar
the belts need to be tighten some more thats all it is
Old Aug 2, 2009 | 09:13 AM
slow_yota's Avatar
Yep, just a loose belt.
Its not hard to do.
- take your wheel off.
- remove the plastic that hides the engine compartment.
- loosen [dont remove] the bolt on the tensioner pulley, IIRC its a 14mm, May be a 12mm.
- tighten up that weird lookin bolt on top of the tensioner pulley. [14mm]
- go back down under the car and tighten up that pulley bolt.
- Put it back together.
Old Aug 2, 2009 | 11:37 AM
asand1's Avatar
Wow, thought you were gonna tell us about a canoe trip.
de da ling da ding
Old Aug 2, 2009 | 12:01 PM
96nismoSE's Avatar
its not necissary to take off the wheel.
-just loosen the pulley bolt with a 14mm wrench
-tighten the belt adjuster(also 14mm)
-then tighten the pulley bolt
then your golden
Old Aug 2, 2009 | 12:45 PM
FallenOne's Avatar
yeahhh, taking the wheel off is okay when youve got a rack... thats about itt..
Old Aug 2, 2009 | 01:06 PM
slow_yota's Avatar
Well its def a lot easier with wheel off.
Old Aug 2, 2009 | 02:46 PM
MaxPR0908's Avatar
Just move the wheel to the right and that will do it..
Old Aug 2, 2009 | 06:01 PM
Galager's Avatar
Thanks guys, I'll take a look at it, or I'll juts bring it back to the spaz that can't tighten a belt right!
Old Aug 2, 2009 | 06:32 PM
pmohr's Avatar
No more Maximas...
You don't even need to get underneath the car to tighten the belt back up.
Anyway, the video will show you how to do it:
Old Aug 2, 2009 | 08:13 PM
Galager's Avatar
^^ Thanks, that pretty much explains it. Loosen pulley, tighten tensioner, tighten pulley, done.
Great video!
Old Aug 2, 2009 | 10:47 PM
slow_yota's Avatar
Great video!
No Prob =]
Old Aug 3, 2009 | 07:10 AM
Galager's Avatar
3 minutes, two wrenches and all with just the hood popped. Real easy fix, thanks everyone.
Apr 16, 2020 05:15 AM
02PearlSE
Oct 7, 2015 02:12 AM
Botnik
Jan 7, 2001 07:32 PM
TimW
Jan 4, 2001 09:36 AM
