Which would you guys get?
Old Aug 3, 2009 | 09:31 PM
maxispeed's Avatar
i can either get a brand new 09 3.5 engine and trans. for 3000. i only get the block, crank and pistons, and have to use the rest of the parts off my engine. but i believe the guy takes out the stock gears in the trans and he puts his own (hes has a machine shop). or theres a 06 with i believe 38000 mi on it. i get the engine and trans with that too for 3000.
so which one should i spend the 3000 on?
and off topic, i have a 96. can i true duel it? and whats the biggest exhaust i can go if i do that? would it be better just to stick to the single pipe and doing a 2.5in exhaust?
Old Aug 3, 2009 | 10:13 PM
mahanddeem's Avatar
Old Aug 4, 2009 | 12:45 AM
maximilia's Avatar
http://forums.maxima.org/all-motor-61/
read, read, and read
Old Aug 4, 2009 | 04:39 AM
pmohr's Avatar
No more Maximas...
$3k is a ripoff for an '06 engine/trans, IMO. VQ35s are quite easy to find for under a grand, and you can get a brand new 6MT from Nissan for ~$2k.
You could put true dual exhaust on anything. You could go with the largest exhaust you wanted.
Old Aug 4, 2009 | 03:20 PM
Product_Of_Korea's Avatar
Well first off what kind of swap do you plan on doing??? Hybrid or 3.5+ECU??
You can only go so far with a block+internals unless you plan to build there will be some modificatons to get your ''3.0'' parts to work with the ''3.5''.
Originally Posted by maximilia
+1
+1
Hell you could probley get
wiring harnesses and everything that you need for a full swap.......
I<3 A32's
Sep 10, 2015 11:07 AM
dcam0326
Sep 7, 2015 07:26 AM
Max139617
Sep 6, 2015 06:02 PM
FanaticMadMax
Sep 4, 2015 02:45 PM
