1995-1999 eFan Wiring Question
Old Aug 17, 2009 | 10:24 PM
DR-Max's Avatar
So I am going to ditch the belt driven radiator fan on my 300zx and install an e-Fan. My primary reason is to allocate more room infront of the engine to work in. Right now, I can barely fit a socket wrench in that area if I had to perform any kind of work there. I would have to basically dump the anti-freeze, disconnect the radiator hoses, and remove the radiator and fan shroud to have room to work in. I've already installed a 4th gen Maxima radiator which bolted onto my Z w/o any issues. I acquired a 1997 Maxima efan from a local wrecking yard. I am going to run the fans off of the Z's ignition circuit. Does anyone know the color code designation of this efan? I realize that this is a 2-speed set-up, I'm not sure which wires to use. I would like to wire the efans in such a way that its always at high speed. I would really appreciate any help from anyone that can tell me which wires to use.
Here is the pic of the wires on each efan motor:
Old Aug 18, 2009 | 06:43 AM
Coolsaber57's Avatar
Uh...not to be an ***, but what does this have to do with the 4th gen Maxima?
Old Aug 18, 2009 | 07:22 AM
96nismoSE's Avatar
the wire colors.
its off a 4th gen....
Old Aug 18, 2009 | 09:31 AM
Woops, you're right.
Try the FSM?
Old Aug 18, 2009 | 06:39 PM
DR-Max's Avatar
I would look it up the FSM if I still have it. I threw it in with the car when I sold it years ago. Thanks anyways. Someone else gave me the wiring diagram.
Old Aug 18, 2009 | 07:34 PM
pmohr's Avatar
No more Maximas...
The FSM is freely available online
The Frye
Sep 2, 2021 11:03 AM
Maxie40
Sep 14, 2015 11:28 AM
Jamie Bowen
Sep 6, 2015 09:59 PM
