5030 O2 sensor location?
Old Aug 21, 2009 | 11:54 AM
magneto112's Avatar
I just need some clarification. I did the ECU self diagnosis and got 5030 Front Right Heated O2 Sensor and 0304 Knock Sensor. Changing O2 first (what previous threads said).
I tried looking for the O2, but not sure if I found it (couple dead links in previous threads unfortunately). I saw something that looked like it near the oil filter (close to the firewall, above and behind oil filter) attached to a cord that I have no clue where it goes. If this is correct, it looks pretty hard to get to. But I will say I was looking at it while the car was not raised.
Also is this the correct replacement part?
http://www.courtesyparts.com/22690-o...ml?cPath=1783&
Old Aug 21, 2009 | 01:59 PM
B_Eaze's Avatar
Thats the correct part. The O2s r in your y pipe, right bank is from the manifolds nearest to the firewall. You should be able to see it from the oil filter side.
If you have an after market Y pipe it will be 10 times easier to change it
Old Sep 13, 2009 | 09:58 PM
defiance's Avatar
Why is that ?
Old Sep 14, 2009 | 04:54 AM
96nismoSE's Avatar
there is waaayyy more room under there with an aftermarket y-pipe because there are no pointless pre-cats and heatshields.
Old Sep 14, 2009 | 05:07 AM
Exactly. It should be extremely easy to change.
Old Sep 14, 2009 | 06:38 AM
haydeno's Avatar
FYI, Amazon sells denso OE fit o2 sensors for about half what courtesy wants(where I got mine)
bbsitum
Sep 6, 2019 07:31 PM
