P1105 / MAP - Solenoid
Old Aug 22, 2009 | 04:57 AM
SSzretter's Avatar
So the other week my check engine came on so I OBD II scanned it and got a P1105 MAP, and it recommended replace the solenoid.
I reset the check engine light and it did not come on for about 9 days - until yesterday.
So my issue is I am guessing if I check wiring, voltages, vacuum, they will probably all check out fine since the check engine light is only coming on occasionally so far.
What do you think I should do?
Old Aug 22, 2009 | 05:22 AM
B_Eaze's Avatar
It coming on occasional doesn't mean it has be replaced. If there is slight corrosion on the connectors or the wiring is beginning to fail those may be bad instead.
The best answer to your question lies in search my friend:
http://forums.maxima.org/4th-generat...gh-idle-p.html
Old Aug 20, 2011 | 01:01 PM
skylinemax82's Avatar
i have a p1105 code on my 97 maxima se and i replaced my solenoid valve and my map sensor and all of the vacuum hoses that connect to the solenoid valve and im still getting the code. what am i missing??
Old Feb 1, 2012 | 08:23 PM
cjanderson3's Avatar
Hey if you dont mind me asking, did ya find anything out about this? im having a really similar problem so I thought i'd ask even though the thread is old
Old Oct 19, 2013 | 02:17 PM
Aburn95's Avatar
Having the same issue and terrible idle in "D"
Old Oct 20, 2013 | 01:25 PM
QueensMAX's Avatar
we had a 99 with only 90k miles come in at our shop with the same code not too long ago.. we changed the solenoid, new hoses,etc...turned out it was a broken wire at the strut tower
Old Oct 20, 2013 | 01:33 PM
Aburn95's Avatar
^I assume the wire was connected to the solenoid? What kind of problems could a bad one cause?
Old Oct 1, 2015 | 07:39 AM
Diesel_hunter's Avatar
Engine stall under a load is 9/10 a vacuum leak, listen for a hiss and track it down or sparingly use starting fluid and listen for an idle change to locate, just be careful not to spray it before the maf
bryants95max
Oct 2, 2015 12:52 PM
viperboy
Sep 27, 2015 07:05 PM
homeofbacon
Sep 23, 2015 07:17 PM
doobadoo
Aug 15, 2015 06:43 PM
bassmann
Aug 3, 2015 07:53 PM
