Tired of manually adjusting dimmer, which wire is it?
Ok, so I searched for many different keywords under 4th generation forums as I usually do prior to posting something and found it was safe to ask so here goes!
Alright so about a year ago I installed my Pioneer AVIC D3 navigation head-unit in my 95 GXE which is non-bose equipped. Everything is hooked up except for the dimmer wire and its just pissing me off having to adjust it manually every damn time. I used installdr.com as a guide and they don't mention anything about a dimmer wire. My friend has a 2005 Impreza 2.5 and when I saw his dim and switch from day to night mode I was completely amazed and kind of pissed that mine wasnt like that!
I KNOW this car HAS to have a dimmer wire because the oem radio (which I didnt get when I got the car) dims when you turn your lights on. Someone please guide me in the right direction, thanks!
bud, why didnt you jsut use the metra harness like you were supposed to =[
h.o lemme look......
mk..
Constant 12V+ Pink/Blue
Switched 12V+ Blue/Black
Ground Vehicle Chassis
Illumination Red/Blue
Dimmer Red/Orange
Antenna Trigger Black/Red
Antenna Right Rear
Front Speakers 6 1/2" Doors
Left Front (+) Blue/White
Left Front (-) Blue/Yellow
Right Front (+) Brown
Right Front (-) Brown/White
Rear Speakers 6 1/2" Rear Deck
Left Rear (+) Red
Left Rear (-) Green
Right Rear (+) Blue
Right Rear (-) Pink
Oh, and hey soemthing that might interest you assumeing you had Bose..
Multiple Amp's/Higher Low Output Voltage
I can honestly say this was the ebst mod i ever made to my Bose system.
mk..
Dimmer Red/Orange
Antenna Right Rear
Left Rear (+) Red
Left Rear (-) Green
Right Rear (+) Blue
Right Rear (-) Pink
mk..
Dimmer Red/Orange
Antenna Right Rear
Left Rear (+) Red
Left Rear (-) Green
Right Rear (+) Blue
Right Rear (-) Pink
mk..
Dimmer Red/Orange
Antenna Right Rear
Left Rear (+) Red
Left Rear (-) Green
Right Rear (+) Blue
Right Rear (-) Pink
btw what is this metra harness?
Hey FallenOne, thanks for your help! Just got done putting everything back together and its finally how its supposed to be. Noticed you're in Kankakee...have you ever visited ChicagoNissanClub.net?
mk..
Dimmer Red/Orange
Antenna Right Rear
Left Rear (+) Red
Left Rear (-) Green
Right Rear (+) Blue
Right Rear (-) Pink
mk..
Dimmer Red/Orange
Antenna Right Rear
Left Rear (+) Red
Left Rear (-) Green
Right Rear (+) Blue
Right Rear (-) Pink
Hey Coloumbian, are your Bose speakers wired through your Pre outs on your HU or through the actual amplifier? casue really, you get one of those bad boys i likked to above, splice some RCS's for the signal wires and rig allt hat up, ZOMG its soo Hot.
I've got an AVIC D3 installed on a Non Bose Maxima, I'll consider it for the g/f maxima which is a 97 SE with bose
MAXSE5SPD
Sep 17, 2022 04:00 AM
The Frye
Sep 2, 2021 11:03 AM
MR2 T'd
Jul 9, 2021 05:06 AM
