Timing Cover/Alternator help
Old Aug 26, 2009 | 10:07 AM
MAX/GTR's Avatar
So I'm driving my maxima and all of sudden the brake and battery light come on. From previous experience I think it's my alternator which has already been replaced and under warranty so no worries. I check the battery and it's fine, and then look over at the alternator and it's not spinning. Well turns out that the bracket that connects it to to timing cover broke off. Hence No tension on the alternator and why my light came on. But looking at the position of things it looks damn near impossible or a real PITA to replace it with the engine in the car. Any suggestions or a write up on replacing a timing cover. Hell if someone lives in the DE area I'll probably pay to have someone help me out.
Old Aug 30, 2009 | 10:03 PM
NISSANMAXIMA91's Avatar
Why can't you just replace the bracket? No need to remove the outer timing cover, let alone the engine.
Old Aug 31, 2009 | 06:26 AM
mtrai760's Avatar
'Trynna' is not a word
Are you saying that the bracket for the alternator broke, or that the timing cover itself broke? The alternator uses a seperate bracket on the top, which bolts to the timing cover and the alternator, easy to replace.
Old Aug 31, 2009 | 08:51 AM
DAVE Sz's Avatar
Hooooooonda.....
Next time ease off on the belt tension...
Old Sep 5, 2009 | 04:46 AM
MAX/GTR's Avatar
neither, there is the bracket that the front of the alternator bolts to, and that bolts onto the timing cover, where it does broke off so the front off the alternator isn't mounted to anything hence no tension. The piece that broke off is on the timing cover so, i have no choice but to replace it.
Old Sep 5, 2009 | 05:03 PM
FallenOne's Avatar
a picture is worth a thousand words in this situation.
Old Sep 5, 2009 | 05:07 PM
pmohr's Avatar
No more Maximas...
It's not that hard to replace the front cover, hardly 'impossible'.
You want a writeup, have you checked the FSM? Read any VQ35 swap threads?
Old Sep 5, 2009 | 10:57 PM
mtrai760's Avatar
Outer cover is easy to replace. Don't remove the engine to do it, that is WAY more work than what is required.
Old Sep 6, 2009 | 10:56 AM
oldngivout's Avatar
Willing to learn
The problem is that the mounting place for the upper alternator bracket is part of the rear timing cover, not the front. Hence, lots more work to replace.
Old Sep 6, 2009 | 02:25 PM
MAX/GTR's Avatar
Exactly
Finally someone gets what part I'm talking about, it looks like a real pain taking off the alternator engine mount and evrything thing else and working in that crammed space tying to unbolt everything and get it off......it sucks dude
Old Sep 6, 2009 | 10:47 PM
mtrai760's Avatar
Once you have the outer timing cover off, the inner is not THAT much more work. Remove the timing chain, the four crank pulleys, and pull the inner bolts. I still would not remove the engine to fix this problem.
If the OP feels that strongly about it though, just do it.
sctludwig
Sep 1, 2022 01:32 PM
mvm062
Nov 30, 2020 09:00 AM
kjlouis
Oct 3, 2015 05:29 AM
trungg86
Sep 4, 2015 04:58 AM
Wareagle92
Sep 3, 2015 07:18 PM
