Redline MT-90 worth it ?
Old Nov 30, 2001 | 06:03 AM
matty's Avatar
I just had that switch on the bottom of the tranny replaced because it was leaking and my macanic put in regular MT oil..?whatever is normal?..Do you think its worth draining again, and putting the redline MT-90 in. Does it make that much of a difference or what ??
How much money ?
Where do I buy ?
Old Nov 30, 2001 | 06:43 AM
190hpKiLLA's Avatar
Granny Driven
Re: Redline MT-90 worth it ?
How much money ?
Where do I buy ?
I noticed improvement, but not right away. It took some driving to get the gears smooth. I can finally get it in first gear at low speeds. And the gears are falling in place much smoother now. Get it!
$45 for oil and $20 for labor with the switch replaced. Good Luck.
Old Nov 30, 2001 | 08:12 AM
IndyMax77's Avatar
How much money ?
Where do I buy ?
I think it's www.redlineoils.com. If not just og to yahoo and search redline oils and it will come up. They have a search function you can use to find local dealers. Do a search on this org for redline and I think there is someone out there with a dealer code or something that'll get you a couple bucks off if you order it.
Can't give you a review because I haven't done the swap yet. But my impression from all the posts I've read about it is a resounding YES it makes a difference
IndyMax77
Old Nov 30, 2001 | 08:52 AM
SuDZ's Avatar
Go for it. I loved the feel after mine went in. I definantly felt a difference. Very smooth shifts now.
SuDZ
Old Nov 30, 2001 | 08:55 AM
matty's Avatar
I'll do it right after Christmas...if I have the money
Old Nov 30, 2001 | 09:23 AM
PhatGuy
Does the old tranny fluid have to flushed or is a simple draining ok before the Redline goes in?
Old Nov 30, 2001 | 09:26 AM
matty's Avatar
I think only Auto's have to be flushed...Manual I believe is just drain and fill
Old Nov 30, 2001 | 09:57 AM
j_bryan's Avatar
Re: Re: Redline MT-90 worth it ?
I swapped my stock 5spd tranny fluid with Redline mt90. the difference wasn't as dramatic as some make it seem. it won't hurt to change it w/ Redline, but you should set your expectations at a reasonable level.
Old Nov 30, 2001 | 02:40 PM
hrmax's Avatar
How much money ?
Where do I buy ?
They have a pretty good price at this site... http://www.myoilshop.com/AutoPrds.html
Use this code to get a discount... 675421
user 11122324
42
Jul 18, 2022 03:35 PM
Forge277
Jun 13, 2016 09:26 PM
lrb6805
Sep 30, 2015 08:12 AM
homewrecker
Sep 24, 2015 07:01 PM
Dasmith
Sep 23, 2015 08:28 PM
