Battery Light on!! Break Light on!!
Old Sep 24, 2009 | 11:45 AM
Infowire's Avatar
So the battery light is on, i just put in a new alternator but that didn't fix the light, i checked all the fuses. The car when running generates 14.8 Volts and when i turn things on (CD player, air) it drops to 13 something.
any ideas? the battery itself is new.
The break light is also on, the hand brake is down, and there is plenty of brake fluid.
also i noticed the air control back light is flickering at times. ... i hope it's not a short somewhere.
Old Sep 24, 2009 | 01:07 PM
whlimi's Avatar
I know you said you checked all the fuses...but just to make sure, check the battery fuse in the fuse box in the engine bay, driver's side.
Check/clean your main ground wire at the battery terminal and on the bell housing.
Do a load test. Turn on your lights/high beams, AC set to max, rear defroster on. Voltage should drop momentarily and then climb back up to around 14v.
Old Sep 24, 2009 | 06:48 PM
Infowire's Avatar
problem fixed.... there was a missing fuse.... alternator one
Old Sep 24, 2009 | 07:30 PM
ColombianMax's Avatar
must be nice...
Old Sep 25, 2009 | 01:24 AM
Maxima9499's Avatar
For those that do not know when the alternator output goes to zero the brake light and battery light does come on in Maximas... at least the 3rd and 4th gens that i've had.
Old Sep 25, 2009 | 05:27 AM
Conrad283's Avatar
I need a truck
Originally Posted by Infowire
The BRAKE light is also on, the hand brake is down, and there is plenty of brake fluid.
Fixed ...
Old Oct 6, 2009 | 04:40 PM
ls1forlife's Avatar
just curious where is alt fuse located? My car does the same thing when i have a full load on it and in the rain. any ideas?
The Frye
Sep 2, 2021 11:03 AM
mvm062
Nov 30, 2020 09:00 AM
ballerchris510
Sep 10, 2015 09:35 PM
markevans999
Sep 10, 2015 04:29 PM
Maxima30
Sep 7, 2015 06:13 PM
