Maxima Wont Start
Old Sep 25, 2009 | 04:49 PM
mantle7yanks3's Avatar
Maxima Wont Start
Please Help Me!!! One night i was driving my maxima and everything was great. The next morning i went to start it up and she wouldnt start! The fuel pump is good, i replaced the fuel filter, spark is good, i check the power to the injectors with a noid light tester. They do not pulsate, i replaced the cam sensor and both crank sensors, but she still wont start. My next though is the computer. Its a '99 Maxima GLE. It only has 95K on it so i dont understand why the computer would blow out. Any suggestions???
Old Sep 28, 2009 | 01:30 PM
DBear's Avatar
What do you mean, won't start? Won't crank? Cranks but won't catch? Catches but won't run?
Old Sep 28, 2009 | 05:43 PM
wai18's Avatar
maybe ur starter is dead.
Old Sep 29, 2009 | 05:00 PM
gotwhatuneed's Avatar
could be a weak battery that's what happened to mine so I Jumped it and after a few minutes it started
Old Sep 29, 2009 | 11:47 PM
KC816MO's Avatar
I just had this problem, I ended up taking of my battery and taking it to O'Reilly's. The battery was fully charged. took of my starter (of course u test the starter by taking it off. attaching the jumper cables to the battery and the starter. if it sparks it still works..) and bought a re-built starter for 60$$. Good Luck!!
Old Sep 30, 2009 | 12:22 AM
ColombianMax's Avatar
Does it actually crank or is it just completely dead? If it feels like its dead when you turn the key but you still have power to the horn, lights, and all other electrical stuff then more than likely its your starter. If your Max is automatic, make sure the shifter is fully placed on "Park" jiggle the shifter if you will..
Try to be more specific when you post as it will yield better result
Old Oct 1, 2009 | 09:09 AM
TLMNICK's Avatar
If your car is cranking, but not starting....and you have a 99, then you might have a problem with the transponder system.
While you're cranking the engine....see if the "security" light is on. If it is, then you have a problem, and only the dealer can fix it.
Old Oct 1, 2009 | 09:34 AM
HandsonMaxima.'s Avatar
^ i agree, sounds like all the other threads about 99's not starting.
immobilizer.
Old Oct 1, 2009 | 06:28 PM
Sorry guys.. it cranks over but just doesnt start.. no its not that starter... im not that much of a noob.. it has to be some kind of electrical problem
Old Oct 1, 2009 | 08:53 PM
Make sure your ECCS fuses next to the battery are not blown or in the wrong slot. Infowire (member here) had that issue just about a week or two ago.
Old Oct 2, 2009 | 08:30 PM
TLMNICK's Avatar
And check the immobilizer as was mentioned before.
kjlouis
Nov 24, 2018 06:09 AM
02PearlSE
Oct 7, 2015 02:12 AM
acw
Aug 13, 2015 12:50 AM
halfpol
Aug 5, 2015 08:24 PM
Jcof88
Aug 3, 2015 10:43 PM
