Car does not start anymore!
Old Sep 27, 2009 | 03:32 PM
Ultrastar's Avatar
Whats good orgers?
I need some help guys
Here's the deal:
It all started tuesday, i go to start the car, crank it up like normal, cranks but fails to start. ok so i crank it longer and it starts.
- wednesday-friday: same issue, have to hold the key in longer than usual to start the car, but it always started
- Saturday: car wont start no more.
Car does not crank and it makes a rapid clicking sound from the dash, the dash lights flickers at the same time.
- Car still can turn on headlights, stereo etc
Is my starter dead?
what can i check?
did some searching and it might be starter relay? fuse? solenoid?
Im off on wednesday so ill work on this during the week
Im still a car noob so be easy on the terms hehe
any help is greatly appreciated,
thanks man
(edit: 98se auto if that helps)
Old Sep 27, 2009 | 03:37 PM
maxx0831's Avatar
I would check the battery and the starter first..
Old Sep 27, 2009 | 03:38 PM
aackshun's Avatar
It's your battery.
I had the exact same problem, just check the thread I started lol.
Here's your sollution.
A.) Clean your terminals, mine were corroded to holy hell, after I cleaned them my car fired right up.
B.) Buy a new battery. Enjoy maxing.
If you were stuck too far away to walk to autozone like I was, buy a can of coke, pour it on the terminals, then rinse with water, let it dry, they drive your car to autozone to buy either or both a terminal cleaner or the spray for battery terminals. Also buy those little fuzzy round things that go around the terminals, prevents corrosion, I used to have to clean my terminals every other week until I brought those.
Old Sep 27, 2009 | 03:40 PM
pmohr's Avatar
No more Maximas...
Check the connections at both the starter and the battery, and have both of them tested as well.
Old Sep 27, 2009 | 07:23 PM
Ultrastar's Avatar
thanks a lot for the quick replies, that was really helpful.
Im glad its just the battery, i'll check it all out when i get home (at work)
It's your battery.
thanks for the info!
your car had the exact same issue? same clicking noise and stuff??
damn how did i miss ur thread lol
Old Sep 27, 2009 | 07:30 PM
aackshun's Avatar
Yup, it got so bad that the clicking became a warning, that it would later be completely dead, no interior lights nuffin.
Old Sep 28, 2009 | 09:29 AM
Ultrastar's Avatar
Hey bro you got a link to the thread you started?
I did an advanced search with threads started by your username but only got 4 results not related to this issue...
did some more research and this guy seems to have the exact same issue:
Originally Posted by RUDDER
´96 Maxima 3.0 QX (V6 24V Automatic) doesn´t crank at all. You turn the key and the ignition relay (on the fuse panel) can be heard. If you open the hood and turn the key I think you hear the INHIBIT Relay (before I thought it was the fuel pump relay).
I don´t think the problem is on the ignition switch because every single time I turn the key I hear the ignition relay. Everything else looks like to work fine (radio, fan, lights, ...) but the starter doesn´t want to kick. I am pretty sure the battery is fine and the A/Theft light also blinks as usual. The lights on the console are normal (airbag light goes off after some seconds, and the rest stays including the “engine check” light). I doubt it is the starter because I never had a problem with it before (always starts easily).
I had some problems with the grounding in the past but I do not think it is that, maybe I am wrong. I hope it is the inhibit relay but I do not know how to test it; with a multimeter maybe?, how?. Could it also be the fuel pump relay?, where is it located?.
Any ideas?, I am puzzled and I really need the car!. Thank you very much.
I read all the steps he did in the noob thread with posts from pmhor but he still wasn't able to get his issue fixed tho...
noob question: if its the battery thats dead, shouldn't all my lights/stereo be out also???
Old Sep 28, 2009 | 09:39 AM
Torreto's Avatar
battery can still have juice and be bad. It could have enough volts to power up lights but not enough cranking amps to turn anything over.
Old Oct 2, 2009 | 08:53 AM
Ultrastar's Avatar
*****RESOLVED*****
yeah,
it was the battery, connections were clean except some grease here and there.
Bought a new Motomaster battery for 110, returned the old one for 10 bucks lol,
tested the alternator, working fine.
Damn with the battery it fired right away! insta-crank, man what a good feeling!
Now onto next problems...
Old Oct 2, 2009 | 09:46 AM
acclimate's Avatar
I'm getting a clicking sound too. I probably have to get a new battery, but its a pain to get it when the car won't start.
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
Balkins
Aug 12, 2015 06:39 AM
