1997 Starting issues
Old Sep 28, 2009 | 06:45 AM
Shift's Avatar
Hey guys,
Maybe someone can chime in.
This past weekend I scored an 1997 maxima for a cash car for my wife to scoot around town.
I am little concern about the way it starts.
It sounds like when I turn over the engine, it take about 4 seconds to get it turned over. It sounds like as if the battery is weak and almost dead.
However, I did take the car to get the battery tested and it passed with flying colors.
Anyone else have any ideas what it could be?
(this is an automatic (fyi))
Thanks all
Old Sep 28, 2009 | 07:00 AM
cashoit's Avatar
Does the car start everytime?
If its taking a little while to start...there are a couple of culprit under the heading of fuel delivery or starter circuit. If its taking a lil while to turn over then the fuel pump may be crapping out. But if thats the case, then the car will stutter sometimes upon accelerating too. When starters go bad...the car will either start of not. Period.
I think take a look at the Haynes manual and see what it says. There is a troubleshooting menu in the front of the book that should be able to narrow it down. If u dont have one maybe one of our kind members will hook u up.
Good luck
Old Sep 28, 2009 | 07:19 AM
Shift's Avatar
Good luck
No hesitation / stutter and it does start everytime it just sounds like a weak battery if you get the idea.
I would call out for bad starter, but its not like the starter solenoid is not click or does nothing (like a dead battery would).
My guess is it can be a weak starter?? I mean since the battery past the battery test?
I doubt its the fuel filter / system. Car runs great once it's on
Old Sep 28, 2009 | 07:43 AM
Nopike's Avatar
Starter is easy to pull and get tested. If it's the original starter replacing it will prevent issues in the future.
Old Sep 28, 2009 | 07:57 AM
wai18's Avatar
it could be the ignition switch.
Old Sep 28, 2009 | 08:03 AM
Shift's Avatar
U think it can be the issue?
Not sure if it is the original starter since it does have 180K (miles)
Old Sep 28, 2009 | 08:40 AM
cashoit's Avatar
Yeah...Might be the ignitions switch.
Whitemaxima was havin similar issues with his car having trouble starting. only cost him like 25 bucks for a replacement ignition switch. His thread is in the 4th gen max section.
Its jus funny that the car would crank for 4 or 5 seconds. Maxi's dont do that. Still check the starter too.
Old Sep 28, 2009 | 08:44 AM
rcg9999's Avatar
YEAH IGNITION SWITCH 25 BUCKS @ http://www.trademotion.com/partlocat...?siteid=214865
Old Sep 28, 2009 | 09:35 AM
Shift's Avatar
I am gonna check all the grounds and also if same occurs, then I will pull out the starter to get tested.
I'll post back the report. Thanks all
Old Sep 28, 2009 | 10:15 AM
WhiteMaxima9600's Avatar
Yeah, If it is the ignition or the starter either are a pretty easy fix. Be sure to check out the pmohr thread on changing the switch, there's also a great vid on there. Good luck.
Old Sep 28, 2009 | 01:28 PM
Shift's Avatar
So whats the deal on the ignition switch? Does this mean that a new key for the ignition "if" I need to replace this switch?
Old Sep 28, 2009 | 01:52 PM
NO, you need not replace the lock cylinder just the small electrical part behind the cylinder. Check out pmohr's thread on this, it's very detailed with good clear pics. Cost you about $30 for a new one.
Old Sep 29, 2009 | 08:51 AM
bigd480's Avatar
I'm having same issue - car takes a few seconds to start, sometimes multiple cranks. Starter has been replaced (about 40k miles ago). Battery is new, contacts are clean, car runs smoothly. How do I diagnose the ignition switch?
Old Sep 29, 2009 | 09:55 PM
eloso1204's Avatar
sounds like its the ignition switch.... not 100% sure but can autozone check this out?
Old Sep 30, 2009 | 05:40 AM
Esmug's Avatar
I am having this issue also. I m just looking into this so this may be dumb question. but why would the ignition switch be faulty if the engine cranks? Does it control fuel delivery at startup ? If my car sits Overnight it requires 3-4 cranks before it engages, then proceeding startups are normal. My intial thought was fuel delivery, fuel pump or some valve that stops fuel from draining back to gas tank, leaving the fuel line with air.
Old Oct 12, 2009 | 08:49 AM
Shift's Avatar
Hey guys.... where is a DIY instructions on the installation of a Ignition Switch?
I am going to go on ahead and put a new one in. Thanks all.
MAXSE5SPD
Sep 17, 2022 04:00 AM
mvm062
Nov 30, 2020 09:00 AM
02PearlSE
Oct 7, 2015 02:12 AM
cruce91
Sep 20, 2015 10:23 AM
Maxima30
Sep 7, 2015 06:13 PM
