bose speakers not working
need some help...i have a 95 gle..bose head unit....decided to change the bose head unit to kenwood.....the only speaker working is right front...went back check all connection seem to be ok...what else should i check....r there fuses for the speaker?
from what i remember, these speakers are amplified with a 2 ohm amp??? and the newer head units are 3, so there not compatible with each other. there is a way to do it, are you aware of the search???? its above the a in maxima.org. please search, i know you'll come up with an answer to solve your issue.
Go all Bose or all aftermarket...IMO.
http://forums.maxima.org/4th-generat...-speakers.html
I don't know, why don't you do a search? Use the advanced option and set the "sort by" field to "relevancy". Type in your search string, in this case "Metra 70-7551" (without quotes though, you don't want to search for the literal string "Metra 70-7551" , but you want to search for the keyword "metra" and the keywork "70-7551"), and hit the search button. I tried it and got 19 results in 0.02 seconds, which is much faster than the time it took me to respond to your last post.
6spd4dsc
05-09-2022 12:30 PM
vingodine
45
05-21-2016 12:46 PM
jerrod99_se-l
08-27-2015 08:27 PM
