11 year old radiator: how long can it last?
Old Oct 19, 2009 | 12:39 AM
  #41
'96 B-rad's Avatar
I replaced mine at about 140k miles since it started overheating. Was only like 200 after the install I think so wasn't a big deal. But speaking about coolant system somehow my coolant line bracket(?) broke and started spilling out coolant and it ran me $360 to get it fixed at pep boys since that was the only place opened and I needed it back before I went back to school. Prob got ripped off but oh well couldn't be helped. That was a few years ago and haven't had any issues since.
Old Oct 19, 2009 | 07:29 AM
  #42
99 Max ES's Avatar
Originally Posted by Feldman
your alternator or starter or any number of other parts might fail stranding you too. I understand the concept of maintenance and replacing an aging part but you have to draw the line at some point. simply inspecting the system i believe would suffice in this situation
Agreed.
A radiator is not generally replaced under preventative maintenance like a timing belt, or drive belt. It is a somewhat expensive part, but it is easy to replace, and can be done by any repair garage in the country, if you happen to be traveling if and when it fails.
at 200$, a radiator replacement is worth 10% of the value of the car in parts alone. I wonder if the OP has any idea of the value of a high mileage '98 maxima in the Toronto area. It ain't pretty.
If i were you I'd be looking to keep it rolling for as little as possible.
Old Oct 20, 2009 | 12:34 PM
  #43
deezo's Avatar
Originally Posted by fastisnothing
You guys are all nuts.
DO NOT REPLACE A RADIATOR UNLESS NEEDED.
A radiator is a merely a box that cools hot fluid. If its not dented, gummed up, not cooling or leaking, ITS PERFECT AND CANNOT RANDOMLY FAIL.
As for the water pump, YES they can go randomly, but thats like fixing a flat tire before you run over the nail just in case. Fix it when it goes. If you spend money fixing a perfectly working water pump, and it would have never broke in the first place, you wasted money. NOTHING WILL HAPPEN WHEN IT GOES. PUMP STOPS SPINNING. CAR WILL HEAT UP. TURN OFF, COOL DOWN. DRIVE A FEW MILES. WHEN IT GETS A LITTLE OVER OPERATING TEMP, TURN OFF AND REPEAT. Dont let recommended STEALERSHIP REPAIR INTERVALS TRICK YOU.
THEY SAY REPLACE IT....ITS TO MAKE MONEY.
I see Pmohr already replied to you but I will say that mine randomly failed at about 265K miles. Started leaking around the seams. Changed my hoses along with the radiator as they were all original from the factory.
Old Oct 21, 2009 | 12:29 PM
  #44
holymoly's Avatar
Originally Posted by pmohr
http://forums.maxima.org/5th-generat...t-writeup.html
All but identical. I might be swapping out my rad today, I'll make a vid if I do. Still have a PS belt vid to edit and upload...
pmohr, is that vid still on the editing floor?
Old Oct 21, 2009 | 05:36 PM
  #45
pmohr's Avatar
No more Maximas...
Indeed. I'll try to do something with it tonight, but it's a crap video anyway.
Old Oct 22, 2009 | 07:06 PM
  #46
trooplewis's Avatar
Rats, I knew I should not have been following this thread. My kid with the 96 max and 165,000 miles pulled into the driveway as I was changing the oil on my Altima. I told him to pop the hood and I'd check his oil level.
I opened the hood, and what a MESS. No, it is not a catastrophic failure, just a minor leak on the top part of the plastic where the company ID letters are; a pinhole leak just below the letters.
Problem is, the fine spray of coolant coming out there got sucked back and covered the entire engine bay with yucky grime. WHAT a PITA that is going to be to clean up.
I (temporarily) fixed the leak with some 5-minute epoxy and capped it with a piece of plastic so that if it does fail in the same spot at least the water will go down the front of the radiator.
So I guess I've gotta order a new radiator.
Rock Auto seems to be the consensus?
Old Oct 22, 2009 | 07:15 PM
  #47
pmohr's Avatar
No more Maximas...
Originally Posted by trooplewis
R
That's where I got mine, ~$100 shipped, definitely looks to be a good unit.
Old Oct 22, 2009 | 07:23 PM
  #48
trooplewis's Avatar
They have 5 or 6 of them, which one did you get?
Old Oct 22, 2009 | 07:31 PM
  #49
pmohr's Avatar
No more Maximas...
The 'Spectra Premium', $105.24 shipped.
Old Oct 22, 2009 | 07:57 PM
  #50
trooplewis's Avatar
Found that one (the Spectra Premium, made in Canada) on Ebay for $85 shipped, with a "make an Offer" of $75...maybe.
Old Oct 22, 2009 | 08:03 PM
  #51
holymoly's Avatar
As good as Koyo Rad?
Old Oct 22, 2009 | 08:22 PM
  #52
trooplewis's Avatar
Probably somewhere between OEM and Koyo, but half the price.
Old Oct 24, 2009 | 07:29 PM
  #53
holymoly's Avatar
Thanks for all your help.
Anyone know where the old rad can be recycled properly?
Old Oct 25, 2009 | 10:15 AM
  #54
deezo's Avatar
I just put mine in the trash. Trash companies will go through it all at their plant and dispose of it properly.
Old Oct 30, 2009 | 01:20 PM
  #55
trooplewis's Avatar
Originally Posted by bamboomerang
changing a rad is less work than removing a wheel.
I'd REALLY rather change a couple of wheels.
Did my radiator today, and it was a 2.5 hour PITA.
If everything went the way it should, probably an hour, but Murphy was hanging around.
Plus I bet you guys that can change them fast have a CAI system and all the factory air intake plumbing is not in your way. 20 minutes right there getting everything out of the way, and putting it all back in afterwards.
matts95max
Apr 23, 2025 10:44 AM
mvm062
Nov 30, 2020 09:00 AM
captchaos
Mar 15, 2016 12:18 PM
JoshG
Sep 16, 2015 08:56 PM
Maxima30
Sep 7, 2015 06:13 PM
