Airbag Control Module Part Numbers (what years can be swapped)
Old Oct 14, 2009 | 04:14 PM
kingofquartz's Avatar
I am hunting down a used airbag control module for my 99 GXE and I have a question about the part numbers.
My 99 GXE doesnt have side airbags and I found a salvaged 98 GXE without side airbags that has a intact SRS system. I pulled the airbag control module and the part number on the side is a bit different from the number on my 99.
The 99 GXE part number is 28556 4L600
The 98 GXE part number is 28556 1L260
I need to know if I can use the 98 module in my 99. Anyone know if the two years can be swapped?
Old Oct 14, 2009 | 06:10 PM
pmohr's Avatar
No more Maximas...
It should function the same, best I can tell. Same connector pinout, everything seems to be the same.
Old Oct 14, 2009 | 06:25 PM
Thanks pmohr, I figured they are the same but I just wanted to check. Didnt want to install it and have something go all haywire with the system. You wouldnt happen to know if replacing the airbags and module is all I need to do in order to reset the system would you?
Old Oct 24, 2009 | 01:30 AM
FYI, the module worked fine. SRS system is back up and running. So anyone who checks out this post in the future knows that its just the first number that matters.
Old Oct 25, 2009 | 06:17 AM
Kevlo911's Avatar
Kevlo for President
As I recall, the SRS in the 95-97 are very similar and in 98(99) they changed it.
Old Oct 25, 2009 | 06:50 AM
nsnrider's Avatar
IIRC, the airbags module for the 99 had a slightly different programming for the airbags to deploy a fraction of a second faster. Whatever it is, it will work fine in you application.
mrc00l88
Jan 25, 2024 01:14 PM
ah2002
Mar 9, 2016 01:42 PM
sc10692
Aug 9, 2015 09:37 AM
ViciousVQ30
Aug 5, 2015 05:40 PM
BassAddictJ
Aug 4, 2015 11:38 AM
