Broken Headlight
Old Oct 15, 2009 | 10:27 AM
asand1's Avatar
Broken Headlight
When I bought my 96 it had a BB type hole in the right headlight. 1/8th" hole with backside broken leaving an inverted cone shape. the broken piece is still there in the housing.
1 Are glass lenses the norm for 96?
2 Has any one ever glued one back together using epoxy or the like?
3 Does any one have a cheap extra?
Old Oct 15, 2009 | 10:50 AM
Coolsaber57's Avatar
1. Yes.
2. I'm sure they have
3. Which is the right-side? Driver's side or Passenger's side? If it's the DS, PM me, I have one.
Old Oct 15, 2009 | 01:01 PM
asand1's Avatar
Right side = passenger side of car, car has a left and right just as we do.
Thanx Saber, wrong side tho.
Old Oct 15, 2009 | 01:43 PM
JtzMax's Avatar
Whatchyou say?
You may try the classifieds 4g forums. Or, PM Maxima Joe, I bet he's got one.
You can remove the old lens by putting the whole headlamp in the oven (oven at 150 F) for a few moments. It softens the glue and you can remove the old lens. Be careful, it's gonna be warm. Also, when you are prying the lens off (I used a wide flat blade screwdriver) be gentle, don't pry too hard. If it doesn't come off easy, re-heat it, it should almost fall off. Or ... easier yet, just replace the whole thing. lol
Old Oct 15, 2009 | 05:58 PM
Dave H.'s Avatar
PM sent. I have the pass. side 95/96 light you're looking for.
Old Oct 18, 2009 | 07:50 PM
asand1's Avatar
Well I separated my headlight housing and glued the broken piece of glass back in. Reassembled everything and works fine, time will tell how the glass holds together.
Only problem was I broke the back half where the left/right adjustor socket pops in. Glued it back together with some contact cement I had.
Hang on to that headlight Dave, I just might call if this doesn't work.
litch
123
Jan 4, 2024 07:01 PM
tarun900
19
Dec 20, 2021 06:57 PM
doctorpullit
Oct 28, 2019 10:58 PM
trsandrew
Oct 25, 2015 02:47 PM
Noela
Sep 26, 2015 08:22 AM
