Checking out my voltage on my hazard and my defroster buttons
Old Nov 13, 2009 | 09:57 PM
vqmaxman's Avatar
I have been having problems with my defroster button and the hazad
buttons,there not lighting up,but however the buttons are doing the job there
supposed to do when I want them in use. I want to know what do I have to do
to get the buttons lighting up the board again. I have the ohm voltage reader
and how do I use the ohm voltage reader.
Old Nov 14, 2009 | 05:36 AM
ajm8127's Avatar
Using the FSM, look in the electrical section in interior lighting. Find where it talks about those buttons, and figure out which pins on the connector power the lights. Write down the numbers or draw a small diagram of the connector and then go out to your car. rip your dash apart and unplug the harness to the buttons. Using the pinout of the connector, switch your meter to resistance mode and take a reading across the two pins that connect to the bulb. For a three watt bulb, the resistence should be around 50 ohms on a 12 volt system.
Old Nov 14, 2009 | 02:21 PM
vqmaxman's Avatar
I just downloaded the FSM and I looked at the EL section, It did not really
tell me anything about what pin goes into where. Is there a section that
you know of and you can pinpoint it to me. Thanks.
Old Nov 19, 2009 | 07:11 PM
vqmaxman's Avatar
I downloaded the FSMs and there not working right, can someone get the actual page out for me and tell me what do I set my OHM voltage meter on. Is it the DCA,DCV,ACV.
Thanks.
Old Nov 20, 2009 | 04:33 AM
Bassbreaker's Avatar
Thanks.
Ohm voltage lol....DCV i believe
Old Nov 20, 2009 | 06:34 AM
njmaxseltd's Avatar
Did you check to see if the bulbs are burnt out? Very common as both switches use two bulbs. One illuminates it, one indicates the device is on. You can get replacement bulbs at Radio Shack. Just reuse the colored sleve on the original bulb.
Old Nov 25, 2009 | 07:51 PM
vqmaxman's Avatar
I finally got the time to tear up the dash, so I can take a look into the switches. I am using the ohm reader and I have it set on resister mode and i am getting a 41 ohm instead of a 50 ohms on the defroster button. If I want to look at the bulb what do I have to do.
Old Nov 26, 2009 | 05:56 PM
vqmaxman's Avatar
I want to take the bulbs out, how do I take the switches apart to take the bulbs out.
Old Nov 26, 2009 | 08:56 PM
Nopike's Avatar
The switch is two pieces that are held together by tabs. You need a small screwdriver to very carefully pry the switch apart at these tabs.
Old Nov 26, 2009 | 09:08 PM
ankkafdras's Avatar
Читаем чужие &
Контроллер телефона с возможностью скачивать смс.Теперь любой человек имеет возможность читать чужие смс и смотреть журнал звонков за последние 3 месяца, даже если их удалили с телефона.Проверьте своего любимого или любимую. Как говорится - доверяй, но проверяй.Ссылка на ПРОЕКТ http://soblazni-ee.ru/
AaronL
Nov 15, 2020 11:52 AM
chernandez1278
Sep 16, 2015 01:18 PM
BrandonCause
Sep 14, 2015 10:41 PM
intimidator
Sep 5, 2015 07:23 PM
