Headlights blink~
Old Nov 14, 2009 | 08:22 AM
t65k3's Avatar
Still Learning
Headlights blink~
I used to have 9004 HID with shields. One day I noticed that the HIDs sarted to blink occasionally. Since they were bright, I could notice that pretty easily. I thought that was the HID ballasts acting up, so I switched back to regular 9004.
While I am getting used to regular 9004s again, I noticed that the headlights' got some problems still:
1. When I turn them on, they two don't come on together. The driver side usually comes up first and 1sec later the passenger side comes on. That usually happens when I turn them on the 1st time of the day.
2. When blinkers are on during the turn, the headlights act fine. When I finish the turn and blinker turns off, the passenger side headlight blinks once or twice and becomes steady on.
Relay? Wiring? Or others? I checked the wiring, no visible damages.
Thanks in advance. Any suggestions will be appreciated.
Old Nov 14, 2009 | 01:53 PM
maxgtr2000's Avatar
KH3 by popular demand
Could be the headlight switch acting up.
Old Nov 14, 2009 | 07:42 PM
I'm also thinking the headlight switch. I know if I turn my lights on slow enough, 1 will turn on before the other. Same thing when I flip the high beam.
Old Nov 14, 2009 | 09:52 PM
nitromax's Avatar
i'm thinking the same thing for the same reason. switch may be just worn out, from the years of use. check your connections/plugs on the switch.
Old Nov 15, 2009 | 12:31 AM
t65k3's Avatar
Still Learning
Thanks for the suggestion, guys.
Is this "[25540] HEAD LAMP TURN SIGNAL SWITCH" the one you mentioned?
(ref. http://www.courtesyparts.com/)
If so, I will try to take it apart first and see if I could clean the connectors for the headlights first.
Old Nov 15, 2009 | 08:13 PM
t65k3's Avatar
Still Learning
Just bought one from one of our members. Will install it and see.
Thanks guys.
Old Nov 30, 2009 | 12:36 PM
t65k3's Avatar
Still Learning
Got the switch from Ilyak, fast shipping and nice packaged BTW.
Checking the ESM trying to figure out how to replace it and ran into this question:
There are two special bolts, one on each side, Torx T50. According to ESM, it's got some bonding agent coating and needs to be replaced after removal. Am I reading it right? Is it necessary (or a must) to replace them?
Old Nov 30, 2009 | 02:18 PM
RA021526's Avatar
I didn't need to remove any specials bolts when I replace my headlamp switch. There are some screw underneath the plastic cover on the steering column, take those out, and then you can pull the top and bottom apart, there's also a plastic piece for the ignition, you can take that off too. Once those are off just unplug the wires to the switch and there should be two screws to come out and then the switch should just slide out.
Old Nov 30, 2009 | 02:23 PM
t65k3's Avatar
Still Learning
Thanks for the info. I thought I had to pull the airbag out first according to ESM. Glad I asked the question here. I really appreciate it.....
Old Dec 2, 2009 | 01:00 PM
Roymg's Avatar
On my 94 the driver side headlite would come on by itself while parked. It was caused by the headlite sw block/blinker combo sw on the steering column. I took off the cowing and sprayed some TV tuner cleaner on the cu. reeds. Problem cured. The sw block cost about $60 new. I'm assuming the 95's have the same set up.
doctorpullit
Oct 28, 2019 10:58 PM
trsandrew
Apr 8, 2016 06:45 PM
knight_yyz
Nov 1, 2015 01:34 PM
trsandrew
Oct 25, 2015 02:47 PM
Noela
Sep 26, 2015 08:22 AM
