Car is hesitating
Car is hesitating
Folks of the MAX. I am experiencing possible engine trouble. (no codes) First, this has happened to me once before. Poor choice of gas. 93 from Walmart. Normally, it's good gas, I guess it just so happened to be not that day. Drove the car around for the day, went home, shut down and did not start back up until the next day, later in the evening. Then the car started to sputter. Thinking this was the exact experience I had with bad gas during the summer, I put in Stabilizer in the tank. Thinking this would have worked, nope. But, the very next day, started the car and it was fine. (still no codes) Well, over a course of 24 hrs, it started again upon starting the engine. (no codes) Ok. This is what I did for the past two weeks until now:
Changed the spark plugs, Ran Sea Form through the break line to the engine, changed out the air filter, fuel filter, oil change - including oil filter change, too, PVC valve, cleaned the TBI, cleaned the MAF sensor and then still no change.
I was suspecting KS or O2 sensor but I am not getting any codes. Check engine light not on.
Could be timing out, don't know enough about the 4th generation engine. So, guys and gals, can you help this old timer out?
Does it have trouble above 2500 rpm...thats classic MAF issue. Clean the IACV. Might want to check ECU continuity. Read some of the latest threads, ppl been having sputtering issues. And that can be caused by incorrect timing or bad air/fuel mix. That would lead me to bad MAF, IACV, or Coil Packs.
HOw many miles on the car. Might be time to change all. Least u know everything with them is cool. Grab a used ECU if none of that stuff works. Do a search..there all type of threads on these types of issues
WTF!!! 368k thats Fawking sweet!!! i love these cars.
YEah man...jus hit the JunkYard and get a used one.
If it was the IACV it wd shut off at idle and not stutter while drving. But it down hurt to clean it too.
the problem prolly is upstream in the Air flow at the MAF. WHen u cleaned it did u use a cleaner or did u jus brush it. There is a how-to on the cleanin procedure. I hear there is specific MAF cleaner too.
Oh yeah! Keeped it up pretty good. It was my fathers car before he past away. I cleaned the MAF with the MAF cleaning spray. Not sure about brushing the screen. Looks fragile. Read the directions and just let it air dry. I have done that procedure at least twice now. I have placed an order for a MAF just now. I am going to also clean the IACV too. I have to hurry and get my order in for the gasket. My wife will be getting off for her lunch break shortly. My car is now in the shop and I am going to guess they are going to say it's the MAF or IACV. I just wanted them to have a look before I started into anything else.
Jus to be clear...its not "searching" or taking a lil while to switch gears? Is it an auto? There was a thread on this pheonomon. if its searchin for a gear, especially between 3rd and 4th gear, more than usual, then the AT is starting to go man...sorry
Just got word from my mechanic and it could be two things, a coil or FUEL INJECTORS. Clog not enough fuel getting to the cylinder or spark. When I removed the spark plugs i noticed one of them looked a little darker than the other 5. I think it was front side, #2.
How do I home test a coil pack? With what?
what do u mean darker? a little more burned or worn?? Or like there was oil on it. I think the coils are like 20 bucks each online.
Im not sure how to really test but do a search ppl have come up with home test.
I wd say to test the coil packs...with car runnin, remove the electrical connector to the coil pack one at a time. Dont worry it wont hurt the engine. U will jus be runnin one cylinder less. The engine SHOULD stutter cuz u running less cylinders. But in yur case, once u remove coil # 2 the car will remain the same since we think that is the screwy coil pack. If the condition of engine doesnt change then that coil pack is busted. If u disable a coil pack, the engine SHOULD run less smoothly. If there is no change with the way the enigine is running, then that coil pack is messed up.
It's just trying to find the right one. I would hate to by all of them. But, i could just buy one, one for the front and one for the rear and trace it that way. OR, just use a meter and see how much voltage it's supporting. Current flow. (scratching head) I will keep you posted on what is going on. --- 369,910 Miles on a 95 Nissan Maxima, GXE. And this is the hassle I am getting now.
Good evening folks. I just put in some strong fuel injector cleaning and it's making it worse, it seems. If I did not have this problem, the car would be running soooo damn sweet right now. I've basically gave it a tune up. Now, either I have to play with the coils in the morning OR go find a fuel pump. I found that in my book of Hong Kong PHONEY for Maximas. lol. Keeping one an all posted.
Just received my MAF and two coil packs. I am going to test the MAF first and then the coils. I bought two, one for the right and one for the left. I am betting its going to be #3, front. The fuel injector cleaner is helping some. Hard starts in the morning but it's getting cold here in Alabama. I am going to apply tonight so, i will post something tomorrow or tonight. Wish me luck.
I have about 10 coil packs for the 95-99 maxima...I know one is bad but the others are good. anyone interested in them? I can't post new threads yet or I'd put it in the sell forum. Let me know and we can make it happen after the turkey weekend.
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
