centering steering wheel
Old Nov 25, 2009 | 07:05 AM
slfalco's Avatar
Ever since my last wheel alignment, the steering wheel is not centered when the car is going straight. Per the FSM you can fix this by adjusting the tie rod ends in "opposite directions." Does anyone know which way to turn each side to make the wheels point more to the left? In order words when going straight, the steering wheel is cocked slightly to the left (if I center the wheel, the car drifts right). So I would need to lengthen the right side tie rod adjustment, and shorten the left side, by the same amount. Just not sure which way to turn each side to do this (clockwise or counter-clock wise as I am facing each side of the car)?
Old Nov 25, 2009 | 08:15 AM
Jesse729's Avatar
If it hasn't been too long since your alignment I would take it back to them they obviously did something wrong if the wheel was fine before the alignment.
Old Nov 25, 2009 | 08:40 AM
njmaxseltd's Avatar
Either take it back to the shop to correct or do it yourself. It's actually very easy to do. Look at the threads on the tie rods, you can easily tell which direction to turn them.
Old Nov 25, 2009 | 01:18 PM
f550maranello2's Avatar
dude dont touch anything... take it back and tell them its fawked up..
Old Nov 25, 2009 | 03:56 PM
maxfever1987's Avatar
well before going back, put your wheel straight and stand in front of the car and see which way your wheels are pointing, you may think they messed up but in reality you may need new tie rods.
lowpost99
Oct 26, 2025 06:53 PM
2kmaximel
Sep 10, 2015 08:13 AM
SusieQQ
Sep 9, 2015 12:14 PM
coasterswim
Sep 2, 2015 07:43 AM
