What causes fuel injectors to die?
Old Dec 1, 2009 | 05:03 AM
hornepirate's Avatar
I did a little searching and really didn't find anything except that bad gas will kill them quickly, but ive had 3 injectors go out on me in 6 months and i have 105k. What would cause them to die to quickly?
I dont use bad gasoline either its always 93 Octane Shell or Hess only
Old Dec 1, 2009 | 05:11 AM
It's really odd that you keep going through injectors, especially since you use high octane gas only. They tend to fail if they get gummed up, but I don't see why they would be unless maybe your running lean or rich? I'm not 100% sure on that though (someone correct me if I'm wrong).
Every oil change you should put some SeaFoam in your gas to clean out the injectors and keep them clean.
Old Dec 1, 2009 | 06:23 AM
cashoit's Avatar
Im wondering if the electrical wires are corroded or the contact points jus need to be cleaned. I mean, mechanically they are rather simple, and shouldnt be failing that rapidly. They jus need an electrical signal for correct firing timing. Im wondering if Fuel Injection Distributor (not really sure what its called) is malfunctioning instead
Old Dec 1, 2009 | 11:58 AM
asand1's Avatar
How are they failing?
Leaking (hanging open), or dead (not injecting)? Could be bad harness connectors. Check the terminals in the harness and use dielectric grease.
Old Dec 1, 2009 | 07:02 PM
mahanddeem's Avatar
I heard sometime before that floring the car frequently damage the injectors (do you ?)..just my 2 cents
Old Dec 1, 2009 | 07:47 PM
well i used an ohm meter to test them. one tested out at 16 ohms so i replaced it and i had another that didnt even measure so i changed that one...i have three spare injectors now just in case lol
Old Dec 2, 2009 | 09:35 PM
josmicru's Avatar
BAD GAS . . . Trash and or water in fuel . . . . CLOGGING from cheap gas
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
Forge277
Jun 13, 2016 09:26 PM
maxima297
Sep 30, 2015 03:32 PM
