I finally found the PCV Valve!!! WoooHooo!!!
Old Dec 3, 2001 | 11:11 PM
Maxima97GLE's Avatar
I'm an idiot..... but I finally found it. Someone buy me a beer.
Old Dec 4, 2001 | 04:51 AM
Confused's Avatar
Permanent Maxima.org Resident
Congrats.
Old Dec 4, 2001 | 05:31 AM
Sonic's Avatar
How about a cookie?
Old Dec 4, 2001 | 06:12 AM
Maury's Avatar
you're gonna need a beer when you see what a pita that is to change
maybe i missed a step somewhere, but when i changed mine i had a wonderful time pulling the hose off the old one - there's no room in there! good luck & congrats!
Old Dec 4, 2001 | 07:09 AM
That was a b!tc# to change. Had to cut off a piece of new hose at work. My friend lent me some long needle nose pliers and it was easy after that.
... C is for cookie thats good enough for me. Cuz cookie cookie cookie starts with C...
Old Dec 4, 2001 | 08:08 AM
1Phat Max's Avatar
does it help changing PCV valve??? if so, with what? better performance, fuel economy??????????????
Old Dec 4, 2001 | 08:17 AM
havent noticed anything yet but thats cuz i havent driven it a lot yet. i know one thing... when i pulled out the old one i saw how bad i needed a new one
Old Dec 4, 2001 | 08:24 AM
Stillen_I30's Avatar
the backside of your tb will remain cleaner with your new pcv valve. you wont have to worry cleaning that out so often now.
Old Dec 4, 2001 | 01:14 PM
Sprint's Avatar
i am on this mission this weekend.. wish me luck
Old Dec 4, 2001 | 01:30 PM
RidinOnChrome's Avatar
ok i bought 1 and its sittin in my trunk cause i dont know where it is ....someone help.........also you wanna talk about pain in the a$$ i just changed my fuel filter let me just say that wasnt fun!
Old Dec 4, 2001 | 01:44 PM
mzmtg's Avatar
Minister of Silly Walks
You'll get at least 6hp and 5 mpg increase!!
Old Dec 4, 2001 | 01:46 PM
NYCe MaXiMa's Avatar
yea I changed my fuel filter it was kind of a ***** to get to but not too bad. Prolly because I don't have ABS brakes
here is a good pic of where the PCV valve should be:
http://integra.vtec.net/geeser/megam...v_location.jpg
which reminds me, I gotta change mine too
Old Dec 4, 2001 | 01:48 PM
Sprint's Avatar
thanks.. the FSM wasn't entirely clear.. that picture just did a whole lot better..
Old Dec 4, 2001 | 07:08 PM
gabuchu's Avatar
Disconnect the pcv hose on the other end, not from the valve and remove the one bolt holding it down. Then you can pull the pcv valve off along with the hose.
Old Dec 4, 2001 | 08:24 PM
Soon2BMaxed's Avatar
how much is a new valve?
Old Dec 4, 2001 | 10:18 PM
Maury's Avatar
i have a bad memory, but i think it was like under $5... purolator one @autozone, that is. i don't know how much nissan's is
Old Dec 5, 2001 | 06:13 AM
Sprint's Avatar
i just bought one from autozone $3.19
Old Dec 5, 2001 | 07:08 AM
jiaxima96's Avatar
Originally posted by gabuchu
...and remove the one bolt holding it down.
Would you tell me where exactly the bolt is? I looked at my 96 GXE. Seems to me it's more like a plug-in type of device. I must have overlooked something?
Old Dec 5, 2001 | 07:39 AM
ny96max's Avatar
congradu****inlations!!! and to think you work at Pep Boys and didnt know where it was. PJ your my hero
Old Dec 5, 2001 | 08:31 AM
Dave B's Avatar
Not DAVEB the parts guy
Try spraying some WD40 into the valve if it's clogged. Mine was a bit dirty, but it still passed the "rattle" and pressure test. There's no point in replacing the PCV if you can de-gunk it. Mine had a build-up of soot on the valve cover side and that was after 5 years of use.
Dave
Old Dec 5, 2001 | 09:18 AM
mlocke's Avatar
Dave
That works (or use brake cleaner if you don't have WD40 handy). My personal opinion would be to always replace it considering the cost of the part plus the "relative" difficulty removing/replacing it compared to other vehicles that I've owned ... guess those old GMs did have some relative advantages.
Old Dec 5, 2001 | 05:13 PM
You know the 6th spark plug all the way in the back on the right (the biggest b!tc# to change) well anyways I had to take this thing off to get to that last plug.... that thing is held on by two nuts behind it (the tips of the bolts look like stars) anyway... you'll notice two hoses connected to that thing. the one leading down toward the intake manifold is on the pcv valve... hope u got skinny fingers or a pair of long needle nose pliers.
Old Dec 7, 2001 | 12:55 PM
Sprint's Avatar
the needle nose is your friend
Old Dec 7, 2001 | 01:03 PM
SuDZ's Avatar
I think I might do my plugs this weekend. This can be added on I guess to my list. So does it make much of a difference? What does the valve do?
SuDZ
Old Jan 21, 2008 | 03:41 PM
FishyMan's Avatar
what's the diameter for the PCV valve hose? not the cover to cover, but th eone coming near the back of the IM?
Old Jan 21, 2008 | 03:44 PM
matty's Avatar
Nice bump on a 6 year old thread
-matt
Old Jan 21, 2008 | 03:48 PM
MorpheusZero's Avatar
The ****.... are you kidding me...
Old Jan 21, 2008 | 03:49 PM
Ummmmm..... How about going out and measuring it?
Old Jan 21, 2008 | 03:58 PM
NmexMAX's Avatar
dot dot dot ...
Talk about resurrection, Jesus. on common sense, go out and measure or read your reply in the thread you started.
Old Jan 21, 2008 | 04:03 PM
FishyMan's Avatar
What I really meant to ask was, will the hose type affect the flow ? As fas as I remember, Checkers sells mostly FUEL LINE hoses? I had thought Nissan made 'special' sized hoses or something. In terms of measuring, I've encountered
I'll check my checkers then, though the ones here don't carry much seriously.
*I'm just re-bumping because I searched it and hoped people who have had real experiences with it can perhaps follow up or something.
Old Jan 21, 2008 | 05:11 PM
No, hose type will not affect flow in this particular situation. Fuel line hose is overkill for what you're trying to do, but it will work just fine. Hop on the phone and call Napa, Kragen, Pepboys, Autozone etc etc. if you're uncomfortable using fuel line hose.
Mar 12, 2020 12:06 AM
trailer54
Nitrous
Nov 18, 2015 07:44 PM
cruce91
Sep 20, 2015 10:23 AM
bumpypickle
Sep 20, 2015 08:22 AM
tardrex
Sep 11, 2015 07:35 PM
