Throttle tap shake
Old Dec 24, 2009 | 08:14 PM
skweaky's Avatar
Throttle tap shake
Since Ive had my car it has always hesitated if i let off completely then press the gas sharply to any degree of throttle. in other words. 0 to 1/4 0 to 1/2 0 to WOT. when i say hesitate i actually mean shakes violently and bogs for 1-3 seconds then immediately picks up and runs like a champ. i can start at 1/8 throttle and slam it to floor with no problem. the car has a new clutch flywheel CV's. i dont slam my throttle on a normal basis but is this something i should be working on getting fixed or is my tranny on the out.
Old Dec 24, 2009 | 09:30 PM
aackshun's Avatar
I'm suscribed to like 4 other threads with the same problem, no solution yet... You're probably 5 speed too right?
Old Dec 25, 2009 | 08:42 AM
skweaky's Avatar
yeah 5 speed non vlsd. im wondering if it could be injectors or motormounts given the severity of the shaking. but motor mounts wouldnt describe the bog. my dad said it could be "loading up" but im pretty sure you cant really"flood" our fuel injected cars
Old Dec 25, 2009 | 08:59 AM
aackshun's Avatar
If you tried a search you'd see a multitude of suggestions with no actual solutions, I've done pretty much everything except work with the iggy coils, when I get back home I will take em apart and clean em to see if that made a difference. I'm doubtful, cause in one of the threads the guy just brought set of iggy coils and he still has the hesitating/stuttering issues...
Who knows what it is... At this point in time our cars with mine at the youngest reaching 11 years old, I will just give it up to old age. As long as I still outrun silly 4 bangers from my time period I'm satisfied.
Old Dec 25, 2009 | 10:51 AM
skweaky's Avatar
It honestly feels like a slipping chain on my old atv but the diference is my car holds together under pressure. I'm still leaning towards the tranny or mounts because of the fact that it doesn't do it in neutral
Old Dec 25, 2009 | 10:54 AM
Crusher103's Avatar
u know my car had a similar problem i didnt pay it much mind but when i pulled the motor i found 3 destroyed motor mounts, the 2 lower ones on the crossmember was literally just floating in mid air.
Old Dec 25, 2009 | 12:07 PM
JNCoRacer's Avatar
Just the tip.
Same here. Mounts were destroyed.
Old Dec 25, 2009 | 01:30 PM
aackshun's Avatar
Mine look pefect, except the rear one, looks a little old, it's probably goin to fail in a year or two.
Old Dec 25, 2009 | 01:36 PM
njmaxseltd's Avatar
Check -
TPS
MAF
MAP Sensor
Motor Mounts
Ignition coils
Old Dec 25, 2009 | 04:24 PM
skweaky's Avatar
any way to check the motor mounts without pulling the motor? i was thinking about it today at christmas that my uncles old dune buggy would shake and jerk horribley on the throttle because of a missing tranny crossmember. you had to cruise at 1/4 throttle or it would rock and jerk and accualy slow down with more throttle.
Old Dec 25, 2009 | 04:37 PM
aackshun's Avatar
Visually for any cracks, and since you're manual, with the hand brake up, have a buddy watch the engine movement when you try to engage the car in reverse (or 1st). I don't know what's the allowed movement but mine moves about an inch.
Also gear shifter movement when driving... if the shifter moves around a bit when your accelerating and decelerating then you got a bad mount...
Old Dec 25, 2009 | 05:14 PM
skweaky's Avatar
the shifter "shifts" front to back when switching from accel to decel but idk how much is normal. ill check the engine movement in the daylight tomarow.
user 11122324
42
Jul 18, 2022 03:35 PM
Miket2006
Mar 1, 2021 03:55 AM
Need help
23
Oct 2, 2015 08:56 AM
dshinn
Sep 26, 2015 08:07 PM
