stripped bolt on compression rod bushing clamp *pic*
Old Dec 26, 2009 | 01:54 PM
Maximeltman's Avatar
OK, so I bought a new bolt, but it will not tighten because the inside of the bolt hole is also stripped...any suggestions on how to fix this problem?
Old Dec 26, 2009 | 02:00 PM
f550maranello2's Avatar
yep.. i had the same problem.. i tried to retap the thread and it broke again... so i just went to the next nearest thread pitch size and called it a day..
dont ask me what thread pitch it was cuz i dont remember..
Old Dec 26, 2009 | 02:20 PM
Well nothing has broken..yet.
By nearest thread pitch size, do you mean the next size larger?
Old Dec 26, 2009 | 02:30 PM
And does anyone know what size thread pitch the OEM bolt is?
Old Dec 26, 2009 | 02:35 PM
bryan163's Avatar
You could also weld in a stud and use a nut.
Old Dec 26, 2009 | 02:41 PM
I dont weld but great idea though...
Old Dec 26, 2009 | 03:03 PM
bryan163's Avatar
Drill and tap it is then. Take the old bolt to the hardware store with you. They have a gauge that can tell you what size and thread it is. Then just get the next size or two larger drill bit, tap and matching bolt. Get a Grade 8 bolt if you can.
Old Dec 26, 2009 | 03:22 PM
will do. Thanks!
Old Dec 26, 2009 | 03:59 PM
bryan163's Avatar
no prob and good luck. hope you have a warm place to work. its been cold as a mother here.
Old Dec 26, 2009 | 05:29 PM
ColombianMax's Avatar
I had the same problem on my 3rd gen 2 years ago, I went to the hardware store and got a tap and die and also got bigger bolts. Its got some nice meaty high grade bolts in there now, cant recall if they were gold color or black but they were the more expensive ones
Old Dec 26, 2009 | 05:52 PM
Nope Cold as a mother here, too
Old Dec 26, 2009 | 07:06 PM
bryan163's Avatar
what state do you live in?
Old Dec 26, 2009 | 07:10 PM
bryan163's Avatar
Sounds like a good fix if it's been 2 years. The gold ones are zinc plated for corrosion resistance.
Old Dec 26, 2009 | 09:05 PM
Nebraska...
Old Dec 27, 2009 | 09:34 AM
bryan163's Avatar
cool, thats only about 32 hours from my shop. It's heated and I have taps and welders if you wanna stop by
Old Dec 27, 2009 | 09:47 AM
awesome, do you guys install brake pads? I'm in Illinois which should be significantly less of a drive
Old Dec 27, 2009 | 12:44 PM
hmmmm.....
Old Dec 27, 2009 | 06:12 PM
bryan163's Avatar
I'll show you guys what an ocean looks like
Old Dec 27, 2009 | 06:14 PM
I'm From Cali originally, I lived 1 mile from the ocean
I retapped the threads and I put a new grade 8 bolt in...holds pretty good for now.
Old Dec 27, 2009 | 06:17 PM
bryan163's Avatar
Good to hear. Cali to Nebraska though... That must have been a culture shock
James92SE
142
Jan 2, 2024 09:23 AM
rbarnes
Dec 31, 2015 06:29 PM
maxima297
Sep 24, 2015 08:57 PM
londonflu
Sep 19, 2015 02:33 PM
Bonka
Sep 14, 2015 11:18 PM
