Possible Variable Intake for the 4th Gen??
#83
Generally,
the wheel size will say how much power you can get to the ground for our Maximas. 17 inch wheels do not put all the maxima's power to the ground as efffectively as 15s do, but the 17s, with bigger 235 tires, will corner better.
So, for straight line power, your 205s may be best. If you have 15s, then get a wider tire, like 235/??/15. I'm not sure of the aspect ratio, but that will work best for lauching grip, not the 17s.
DW
DW
Originally posted by rOaD bEaSt
How did you bring this time with stock and with y pipe only are you running street slick or you are using your 17 at the track I can see that they are 235 is that what helped you ?
What rpm do you rev at the launch ?
One more thing who will win a maxima with 17,235,45 or a maxima with 15,205,65 if they were at the same condition and the same driver ?
My quastion does the 235 rope power because my tires ate 205 ?
THanks
THanks
#84
HP is th only thing that will affect top speed. Different tire sizes will affect acceleration, or how fast you get there, due to roling resistance, aero drag, etc.
So, if you have 220 hp with 205s, then you'll reach 250kph quicker than if you had 225s.
DW
DW
The problem that I don't only race for 1/4 mile I'm going for top speed too if I use 15/60/225 this will be as 15/65/205 but I affraid that the 225 will rope my car power ?
Did anyone try this ?
#86
Once we get some concrete info on this I may be willing to try it out... depends on if I have the funds... Also I have a CA/NLEV 99 SE-L so I am not sure if that will throw a wrench in on this either...
Jeff here in the NW may be willing to help me out if I bug him a little bit. :P
#87
THanks
THanks
I slipped the clutch from 2500, thats what i've found works the best for me and its less violent on your transmission as well.
225s vs 205s. The 225s will have more traction but they will weigh slightly more too. Cars on the bonneville salt flats, where they do the high speed record setting for cars, use as skinny a tire as they can, because skinnier tires have less rolling resistance than wider tires.
#89
Originally posted by SuDZ
What would be required mechanicly to do this swap? Would it be a DIY project or no?
SuDZ
SuDZ
#90
Guys if you doubt the usefulness of the variable intake take a look at the Dyno for the supercharged 4th and 5th generation. The 4th generation would be stronger if not for the variable intake kicking in at about 5000 rpms. The 4th generationn has a cam that is more aggrtessive than the 5th generation, which explain the higher horsepower genearated on the lower end by the 4th generation. This data leads me to draw the conclusion that a major portion of the 3.0 5th generation horsepower increase is due to the intake. The amazing jump around the time the intake opens is the leading indicator of the intake's horsepower contribution. Any comments or feedback.
#91
I don't think anyone doubts its usefullness. There's more a worry of possible slight fitment problems between the US and non US 4th gens, and some ECU and/or emissions potential problems. Other than that, we're all ready and eagerly awaiting the variable intake!
DW
DW
#92
Would it be possible to run these ideas by a Nissan Tech at Nissan Headquarters or something? Maybe there's a chance one guy there is actually an enthusiast and might be helpful in answering some questions.
#93
so lets look at it this way 222 in stock trim with different things here and there like no cats and better muffler but say you ran an APEXi S-AFC the variable intake manifold and you already had intake y pipe and full cat back exhaust you could lean out the mixture and hopefully have an air/fuel gauge or egt or something and then you could probably be around what 250?
#95
Just thought I'd bring this thread back since there's so much talk of manifolds. Because the the newly discovered varaible intake for the 4th gen will be in limited supply, hopefully this discussion will get another source for them.
DW
DW
#96
I've got a power loss problem with my 5th gen above 5000 rpms. I'm certain that it is related to the VIAS system.
Look at these dynos - my stock before the problem and after the problem.
The after looks a lot like a 4th gen.
http://web.tampabay.rr.com/maxgator/oldVSrecent.BMP
Now, if I could just get Nissan to admit there is a problem - or find out what the problem is, I would be set.
#97
Problem
Originally posted by Max_Gator
Well, if you ask me that seems accurate.
1. Variable intake partially open, does not open any wider.
2. Engine trouble, intake does not fully open
3. Computer calibration trouble
#98
Re: Problem
Something is not right. Was there a temperature diffence on testing days. The base line before opening is off, it should be the same before opening variable intake runner. There are 3 options.
Clearly though the big difference is after the intake runners are supposed to change at around 5k.
Visual inspection of the actuator on the outside shows that it engages at 5200 in its full range of motion. Nissan Service (oxymoron) performed the vias diagnostic test - which really only tests to see if the actuator is working/getting power. But they refused to do anything more.
They don't accept dynos as evidence of a complaint - whatever. We did a roll-on with another 2k5spd that dyno'd dead on to mine originally and from 4k to about 5750 in 3rd and pulled about a car length.
That wasn't good enough for them - so they refuse to admit problem.
I don't expect to get any satisfaction from them or Nissan so am working on fixing it myself (but still going through the Nissan motions).
#100
Someone did an extensive write up on it on this board. They found it did nothing. This manifold was well designed.
DW
DW
Originally posted by Stillnmax
How much would it cost to just have the intake manifold ported and polished... i mean wouldnt the benefits of that help as well if you consider the fact that the engine would get even more air....
#101
Variable Intake
Hi People.
Sorry I haven't been able to reply for a few months. Things have happened that have meant I havent been able to come here. Just to clarify a few things I noticed while reading this thread.
1. New Zealand manufactured maximas dont have variable intake manifold. they have the same as the US.
2. NZ manufactured maximas dont have catalytic converters
3. NZ imports a lot of vehicles from japan. these have the variable intakes because they are JDM spec.
4. A JDM spec VQ25DE in a cefiro will leave a NZ VQ30DE for dead at top end.
5. JDM spec maximas (defiros) have catalytic converters.
#102
Re: Variable Intake
And so the drama of the high in demand 4th gen varaible intake un-folds with yet a new twist. There are like 4 threads going on about this now. I'll post this in the latest one.
DW
DW
Originally posted by NZ Max
Hi People.
Hi People.
