Bad to chirp 2nd gear?
Old Jan 7, 2010 | 11:46 PM
killerVQ30DE's Avatar
(short post)
With spirited driving I chirp 2nd gear - is that hard on the car?
Does it put excessive load on clutch, engine mounts or anything?
Old Jan 7, 2010 | 11:49 PM
RAZ76's Avatar
Yes, of course it is, you are hard on your car.
Old Jan 7, 2010 | 11:53 PM
aackshun's Avatar
How spirited is "spirited" cause I only chirp into 2nd when I'm really serious... and its usually more than a chirp. Just lag in between shifts and slower on the clutch, that'll be easier on the drivetrain components.
Possibly to your first question.
And yes to your 2nd question.
Old Jan 8, 2010 | 12:40 AM
Feldman's Avatar
probably hardest on your tranny
Old Jan 8, 2010 | 02:55 PM
Nealoc187's Avatar
SLOW
it's not good for it by any means. still doesn't stop most people from doing it (including me) and it probably won't straight up break anything (no guarantees though), more likely just shorten the lifespan of certain components (such as your 2nd gear synchro, clutch, motor mounts if they are still rubber, etc).
Old Jan 8, 2010 | 05:43 PM
Sinturion's Avatar
N00blargh
You're such a hoon killer
Old Jan 8, 2010 | 09:13 PM
trooplewis's Avatar
That's like asking if it's bad to run your car at 5500 rpms.
Not necessarily bad, but it will put much more than twice as much wear on your engine as running at 2750 rpms.
Are jackrabbit starts bad? I dunno, but I never want to buy a used car from someone who drives like that.
Old Jan 8, 2010 | 09:21 PM
93altima's Avatar
Turbo 4th Gen
Trust me the last thing you want to do is put more strain on a 4th gen tranny
Old Jan 9, 2010 | 06:27 PM
saylee's Avatar
very true, no matter what kind of clutch kit you decide to put on, you still have to ease it on the gas. I dont really do 1-2 aggressive pulls anymore, if u want to pull to see if a new component has its value, drop it in to 2nd easy and you'll still be able to pull with less stress on your tranny. But pushing your car to hard to much is bad anytime..
Old Jan 10, 2010 | 09:08 AM
Goomz's Avatar
i wouldnt do that unless the tranny is cryo treated, and still not often. shifting like that in any tranny is bad over time.
Old Jan 10, 2010 | 10:15 AM
burgundyblues66's Avatar
um, what is chirping?
Old Jan 10, 2010 | 11:15 PM
Cheers won't be doing that on purpose anymore
Old Jan 10, 2010 | 11:34 PM
Feldman's Avatar
when you shift hard between gears mainly 1st to 2nd while driving hard you can make the wheels spin a little making them squeal or "chirp"
Old Jan 10, 2010 | 11:59 PM
MorpheusZero's Avatar
Is it bad? Well, yeah. It won't do anything for the first hundred times you do it maybe, then your clutch will glaze over, or maybe your tranny will shatter, or maybe you'll sell the car before you notice any negative effects. It's not good on your mounts but it will take years and years to wear out new mounts.
Bottom line, you can drive a car hard and it'll be fine for awhile, but in general, eventually it will break, and at the very least you will experience accelerated wear.
Old Jan 11, 2010 | 11:02 AM
cashoit's Avatar
yea i got my car from a old lady who never drove the car hard. I can tell cuz the tranny is still stiff lol
Old Jan 11, 2010 | 12:07 PM
yeh I was lucky too mines a 1996 with 1 other owner from new who had Nissan service it as per the book and looked after it so trans feel nice and smooth still
Old Jan 11, 2010 | 04:04 PM
MaximaFan4140's Avatar
Originally Posted by killerVQ30DE
(short post)
dude its a maxima..not a viper or corvette anything wth 300+ base hp lol...if you wanna do some "spirited driving" go to the tracks lol
Old Jan 11, 2010 | 10:51 PM
Would it not chirp on the track also
Old Jan 11, 2010 | 11:00 PM
93altima's Avatar
Turbo 4th Gen
I personally hate 4th gen trannys, I blew 3 trannys when I had a de-k( 1 the diff went and the 2 I killed 2nd and 3rd gear) then I killed 2 more with the 3.5 (1 was because lack of fluid due to a leaking passenger axle seal and the 2nd I stripped 2nd) and to think the car is currently going turbo as we speak lol but I still have that 1 so I plan on gyetting par 2nd and 3rd gear with a phantom grip lsd
Old Jan 12, 2010 | 12:10 AM
6-speed swap.
Old Jan 12, 2010 | 06:16 PM
Nealoc187's Avatar
SLOW
I don't know what you're doing to your transmissions to break that many at that low of a power level but that's another discussion.
About the swap you are planning - that won't work without additional parts or a different custom input shaft than PAR already has available. to get 2nd gear you have to get 1st gear because 1st and 2nd are all a part of the input shaft which in turn necessitates getting 3rd and 4th because PAR designed their input shaft for use with needle bearings under 3rd and 4th meaning stock 3rd and 4th won't work on their input shaft (I know you said you planned on 3rd, but 4th would be required too unless you can convince them to make yet ANOTHER version of their input shaft). so you're looking at like $3-4K (haven't looked at the exchange rate recently, but it used to be about $4400 for 1st-4th). plus labor if you can't build the trans yourself.
just letting you know.
Old Jan 16, 2010 | 12:57 AM
I'm OP so I can jack my own thread
Is it bad to wait at the lights (for example) with the clutch in? you know when you think its about to go green so clutch in and change into first to find it hasn't changed yet and don't want to have to change back to netural - I figure it will wear the throw out bearng more? but not the clutch because thats disengaged
Old Jan 16, 2010 | 09:45 AM
trooplewis's Avatar
No, it's not bad to wait with the clutch disengaged, unless you are 'slipping' the clutch instead of using the brake pedal to keep the vehicle stopped on an incline.
What is bad is if you are at a red light, and you want to be "fast off the line" when it turns green. Those folks are favorite targets of people who like to run late yellow lights, and get T-boned on a frequent basis.
Old Jan 16, 2010 | 11:01 AM
mahanddeem's Avatar
The lights are designed in such a way that the moving direction gets red light before the waiting direction gets green...So you can get T-boned from someone cracking throught the red light (not the yellow one)
Old Jan 16, 2010 | 11:12 AM
MoncefA33's Avatar
One kid told me that I needed to learn to drive stick shift because I held the clutch in at a traffic light. Yes it 'wears' the throwout bearing but then again so does starting your car, driving it, shifting gears, going around turns, etc. The throwout bearing should be fine until the clutch disc wears out.
Old Jan 16, 2010 | 09:03 PM
saylee's Avatar
bro, honestly, just drive it like you drive it and it should be fine..if something messes up at least you'll figure out that it was cause you were to hard on the tranny, if it doesn't then keep letting it chirp... your driving standards are different from everyone on here... drive your car the way you enjoy it and however safe you think you should...
I chirp 2nd too sometimes, its no surprise and oh yea!! our cars can be faster than vipers and corvettes...
Old Jan 17, 2010 | 05:56 AM
dgeesaman's Avatar
Maintenance Monster
Cryo treating won't work miracles. In many cases it doesn't help at all.**
In a stock transmission with bearings in new condition, the shock load of a "chirp" can strip the gears. 3rd in particular likes to shear it's teeth.
Another thing people don't often consider is how you drop the clutch in when it doesn't chirp. This can actually transmit more load through the drivetrain than when the tires get spinning and relieve the torque. High capacity clutches with pucks in particular engage harshly and transmit much higher shock loads to the drivetrain.
I've chirped my tires. Especially in poor traction conditions on cold tires. But you have to be realistic and understand that driving a passenger car hard will unavoidably increase wear and risk of sudden breakage.
**(Cryo is another thing altogether, but when the engineering eggheads test cryo processes for strength improvement, they have found it is very specific to the application. A particular starting material, a particular cold quench process including temperature, stages, and timing, are all critical to reliably getting the same result. The aerospace and racing organizations who are getting improvements with cryo have put a lot of hours and samples into making each application. There is not yet material science theory that allows consistent prediction of the performance of a cryo process. Without significant testing and experimentation, it's unlikely that handing your parts to a cryo treater will make them stronger. I am unaware of anyone who has developed and tested a cryo process that is truly successful with 4th gen Maxima transmission components)
Dave
Old Jan 17, 2010 | 05:59 AM
dgeesaman's Avatar
Maintenance Monster
The life of a group of identical bearings under identical load conditions varies quite a bit. Most of the time the bearing will be fine if this is your habit. However a portion of the bearings will fail before the clutch if you do this. The grease within the bearing also has a limited life. Leaving the clutch in a lot requires the bearing to last many times longer.
Personally I put the car in neutral and clutch out. It takes but a split second to shift into first and get going, and if you're like me you're paying attention to know when the light is about to go green anyway.
Dave
James92SE
142
Jan 2, 2024 09:23 AM
spencerwh1
Jun 30, 2016 05:44 AM
Andy29
Sep 29, 2015 05:32 AM
worldwiderecognized
Sep 24, 2015 06:56 PM
