three way catalyst
Old Jan 12, 2010 | 07:48 PM
metal_god98SE's Avatar
three way catalyst
Hey all..wondering if something can be clarified. The CEL came on and i checked the codes via the vbx maxima site, and it yielded a result of "three way catalyst (right bank)" I'm interested in exactly what that is... I'm assuming its an O2 sensor...but which one? I replaced all three about three years ago when I installed the budget y pipe.
Thanks in advance for all of your wisdom...
Old Jan 13, 2010 | 03:45 PM
...does anyoen have any info to offer? it would be appreciated
Old Jan 13, 2010 | 05:22 PM
Last fall, I replaced the oem cat converter since a hole had rotted out with a warpspeed cat. The car is stock except for the y-pipe, and has 167k on it. A couple of weeks ago, I replaced the pcv valve and fuel filter with oem, and also took the tb off and cleaned it.
What does that three way catalyst mean? I've searched and found no definitive info.. Thanks
Old Jan 13, 2010 | 05:29 PM
Fasteddie01's Avatar
If you run a search on 'three way catalyst', you'll find lots of info. Quicker that bumping your thread.
Old Jan 13, 2010 | 06:21 PM
internetautomar's Avatar
mod or sell?
http://en.wikipedia.org/wiki/Catalyt...rter#Three-way
Old Jan 30, 2010 | 10:33 AM
..so is the cat converter on my car basically no good now?
Old Feb 16, 2010 | 07:22 PM
I replaced the rear exhaust manifold O2 sensor in the y pipe per the suggestion of a mechanic friend that hooked up his diag tool to the car....and the cel came back on. What could be wrong?
Is it the O2 sensor behind the cat...or could the cat converter itself be the problem?
Old Feb 17, 2010 | 12:09 PM
cashoit's Avatar
re-scan and get back to us. Did u reset the ECU after replacing
Old Feb 21, 2010 | 06:26 AM
Yes, i did reset the ecu after replacing that O2 sensor. The code is still the same, 0702
Old Feb 26, 2010 | 09:47 AM
...anyone have any experience with this?
Old Mar 1, 2010 | 09:17 AM
can anyone help with what it might be?
Old Mar 1, 2010 | 06:49 PM
Since you don't indicate what year you are, i checked my 98 code. It doesn't say anything about O2 sensor - what made your 'buddy' think that? Did you R&R the cat fall 09 or 08? Either way, that's prob the issue. Look up pmohr's code reader to see the probable causes - they're listed in order of probability and 02 isn't there. The exh tube leak or intake leak would be giving bad O2 mix at the sensor, and the injectors would be making burn too lean or rich. the codes have the answers, just not the 'Exact' answer.
Old Mar 2, 2010 | 10:25 AM
cashoit's Avatar
Per FSM, I dont see any code for p0702. Rescan and get back to us.
But if the Cat is all rusty underneath and has a whole in it and making alotta noise, then yes time to replace the Cat.
Old Mar 2, 2010 | 11:09 AM
Code 0702 from the ECU, not a scan, shows 3 way catalyst and causes.
NissanNismoZ
Sep 12, 2015 07:30 AM
minsbang
Mar 24, 2004 02:32 PM
minsbang
Mar 19, 2004 04:38 AM
JCW915
Sep 26, 2003 10:28 AM
95seMax
Sep 1, 2003 09:37 PM
