Why do my RPM's jump when I press the brakes?
Old Jan 22, 2010 | 02:02 PM
canIlive's Avatar
So, I'm sitting at a red light yesterday like any other day. As it turns green, I slowly hit the gas and all of a sudden, the RPM's drop down to almost 0 and then shoot back up. It felt like the car was going to completely turn off. It did this 3 times that day.
Now, every time I press on the brakes the RPM's shoot up from about 1500 to 2000. I'm just cruising, doing about 45mph and if I press the brake to slow down, the car slightly jerks and the RPM's shoot up. Any ideas?
*When I bought the car from achebee4you last year, the CEL light was on which was caused by the EGR valve being dirty. This has not been corrected yet. Could this be a reason why my max is performing this way??
Old Jan 22, 2010 | 06:47 PM
mahanddeem's Avatar
check the MAF
Old Jan 22, 2010 | 07:09 PM
VQphantom's Avatar
Iacv clean it or replace it.......and no the egr wouldnt cause that.
Old Jan 22, 2010 | 07:22 PM
mryoungfresh's Avatar
Yes the EGR can cause it if it stuck open and its not closing which mean its leaking exshaut into the intake manifold you may get a random missfire code
Old Jan 24, 2010 | 09:52 AM
SilverbulletMax's Avatar
u should check the MAF cuz that happened to me when i installed my short ram
Old Jan 24, 2010 | 10:14 AM
FallenOne's Avatar
Silver Bullet Your sig is too HUGE Fix It.
To the OP; you could have a number of problems.. EGR, Vac Leak, MAF, IACV.. start with the easiest first.. Clean everything up; IACV TB, MAF (be gentle),if problems persists, get some starting fluid and spray it around the intake manifold and plenum nad what not and check for a vac leak..
have you done anything to the car in recent history?
Old Jan 25, 2010 | 10:14 AM
jdooley's Avatar
Does it do it when you press the brakes without the car moving? Given the braking relationship I would at least check the condition of the hose going to the brake booster. I would also be inclined to clamp shut the brake booster hose and see how it behaves under those conditions. Beware that it will be a lot harder to actuate the brakes without that vacume so you might consider doing it on a stretch of road where there is not a lot of traffic.
Old Jan 25, 2010 | 10:26 AM
cashoit's Avatar
Agreed.
Do the cleaning and get EGR fixed. A lil Chevron Techron Fuel System cleaner wont hurt either lol Woot wooot
Old Jul 26, 2010 | 04:19 PM
canIlive's Avatar
I recently replaced the fuel filter and this problem went away. Solution or coincidence? Hmmm
Apr 16, 2020 05:15 AM
Need help
23
Oct 2, 2015 08:56 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
