is this for real?
Old Dec 5, 2001 | 10:28 AM
skeelo34's Avatar
is this for real?
Is this true? Take a look. Spark plugs that give you 8 hp?
http://cgi.ebay.com/ebaymotors/aw-cg...806253&r=0&t=0
Old Dec 5, 2001 | 10:38 AM
Trev97SE
Re: is this for real?
Too good to be true. I've been told never to try to gain horsepower from spark plugs. They should only be swapped as a response to other mods that may require a different heat range or gap setting.
The only time spark plugs will really make a difference is when your old ones are nearly worn out when you replace them.
Old Dec 5, 2001 | 01:34 PM
Dreizehn's Avatar
I've got some light weight gas if you want, I'll cut you a good deal...
Old Dec 5, 2001 | 01:44 PM
skeelo34's Avatar
How much? How will you ship it? Man those spark plugs and your gas would make me faster than a sc for a fraction of the price!
Old Dec 5, 2001 | 02:24 PM
SuDZ's Avatar
Maybe you can start a group Deal on it.
SuDZ
Old Dec 5, 2001 | 07:19 PM
Dreizehn's Avatar
Think there is a market for it??? I can probably get away with $2.00 a gallon... That's a steal!!!
Old Dec 6, 2001 | 12:47 AM
justmax's Avatar
Jesus Christ did you see this?
/quote
Denso Iridium Plugs Not Only Come with a Lifetime Warranty, but will produce Power Gains on every Car they are used on. Denso Itself tested a Civic 1.8 L race engine and gained 60 HP by switching to their Denso Iridium Plugs over the best Plugs out there.
/quote
Come the F|_|CK ON!! Guys I know some of you are young and don't recognize the shaft when it's coming up behind you, but this one's pretty obvious.
Old Dec 6, 2001 | 01:37 AM
supertool
195 HP gain. Guaranteed.
Just by putting these spark plugs in
You can compare your car with these spark plugs and without sparkplugs. You'll see
Old Dec 6, 2001 | 09:19 AM
SuDZ's Avatar
/quote
/quote
Who needs a supercharger when you can strap on 60HP with just the plugs costing only 70 bucks. What a deal huh. Man combine this with my tornado air filter and I am looking at a 12 second max already. Imagine adding the Y pipe.
SuDZ
Old Dec 6, 2001 | 09:37 AM
HondaKiller718's Avatar
/quote
/quote
Actually they did gain about 60 hp on a drag race civic highly modified engine. It was no street car and there were also other tweaks made to the engine. I might try the plugs soon just to see if there is any noticable diff. I doubt it.
Old Dec 6, 2001 | 11:54 AM
njmaxseltd's Avatar
Iridium Atomic number = 77 Atomic weight = 192.22
Platinum Atomic number = 78 Atomic weight = 195.08
The properties seem just a bit to close to make much difference.
Old Dec 6, 2001 | 12:12 PM
skeelo34's Avatar
Man if you spend that much money on spark plugs, maybe you should be driving a civic and believe the claims!
Old Dec 6, 2001 | 04:32 PM
dkbl97SE
Maxima.org stickers would be your best bet. Since i put mine on, my 0-60 time as well as my 1/4 mile time have both dropped significantly. I have yet to dyno it to see the actual horsepower gains, but i will post the results as soon as i get them.
James92SE
142
Jan 2, 2024 09:23 AM
fx4five
Oct 1, 2015 04:58 AM
